Question about Kenmore 80593 Microwave Oven
Panel seems to work fin but food does not heat up.
  • prakash_vr Dec 12, 2009
    But how hard is it to replace this part? Is this a DIY or do I need a tech?
  • 11,896 Answers
If the microwave works like normal but does not heat up, then the magnatron is faulty. You can get parts, manuals, and more at repairclinic.com or partselect.com
Posted on Dec 12, 2009
  • Nate Stansfield
    Nate Stansfield Dec 12, 2009
    If you can use a soldering iron, and use a volt tester then you can do it. There are videos on the net on howstuffworks.com, acmehowto.com, and youtube that show how to do this.
    You can get the parts and the manual with instructions at repairclinic.com and partselect.com and instructions and testing procedures and more as well.
    The magnatron provides the heat. No heat, bad magnatron.
Sharp 1200w microwave seems to be tripping lightly (can hear clicking noises)and cause heating to be irregular
Clean the food off the inside top of the microwave Now,Or that noise you are hear will stop along with the microwave. The food gets on the Formica Squire which is how the micro waves heat your food. 1st unplug the Microwave then spray the inside of the unit with something like Fantastic or something strong and use glove so you don't burn you hand,Also if you have a scrub brush use it,And clean all the soap out and raise very well.
May 02, 2012 | Sharp Microwave Ovens
Microwave will not heat food everything else seems to work, timer, rotating plate everything works but heating food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
=0=0=0=0=0=0=0=0=0
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
Kenmore Microwave Won't Heat Food
The service manual is here.
Unless there's a bad connection at a magnetron terminal, I would say you have a failing magnetron.
It is part number 2B71165R and you can get it from the Pros here for $68.59 (subject to change).
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | Microwave Ovens
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Feb 15, 2008 | GE JVM1490 Convection/Microwave Oven
Kenmore 80593 Microwave Oven Logo
29 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
