Question about Polaroid i733LP Digital Camera
Lens does not go back in - Polaroid i733LP Digital Camera
  • 6,831 Answers
Hello
I found a link where it explaind this problem and instruct you on fixes for this exact problem. Just click on the link and you will be directed to the site.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Kind regards
Andrea
Posted on Dec 12, 2009
Does not autofocus
Assuming you've made sure the auto-focus is turned on on both the lens and the camera, remove the lens, turn off the camera. Remove the battery. Wait about a minute. Put the lens back on, turn the camera back on . It's a computer basically. Sometimes it crashes. I've had this happen to me a few times.
Mar 13, 2012 | Nikon D90 Digital Camera with 18-105mm...
Tip
Lens Error
Try removing and replacing batteries to reset the camera. Ensure that batteries are fully charged.
If that does not clear the problem, then the lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
on Jul 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
LENS ERROR RESTART CAMERA
The lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Feb 25, 2011 | Canon IXUS80ISS Digital Camera
Zoom lens is stuck out position...won't retract. Power on button produces yellow flashing light on back of camera, then off again automatically after a few seconds. Any hope of getting lens operable...
Lens errors are quite common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended or the camera has been powered on, but the lens had been blocked preventing its extension.
You can try the following:
1. Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
2. Place the camera on it's back and look at the lens from its side. It may look slightly crooked. If this is the case, power up your camera and apply pressure gently to the side of the lens to center it. It should then extend fully.
3. [Try at your own risk] Try forcing the camera lens. Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a click as it pops back into place. If the lens is stuck at an angle, put the edge of the lens not the flat front, on the edge of a table and press the lens back towards the center. It will either click back in place and work or it will break off one of the three pins that ride in the grooves of the lens barrel. Try powering the camera back on.
Alternatively, take a look here for some more tips! http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 06, 2011 | Olympus FE-340 Digital Camera
Errer #45 kodak v610
The problem seems to be with your lens guide it is out of track so please follow the step below,
Try forcing the camera lens but be careful while doing this if something goes wrong your camera our lens can be damage
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
If no luck then contact your Kodak service centre
Thank You
Oct 01, 2010 | Kodak EasyShare V610 Digital Camera
Lens error of casio EX Z300
Apr 18, 2009 | Casio EXILIM EX-Z300 Digital Camera
Lens error
i had the same problem....my problem was the lens was pushed forward and the third zoom was pushed back. so the lens is blocking the cover(thing that covers the lens) so push the lens back carefully with a cottom swab and pull the third zoomer thingy out.
Jul 31, 2008 | Nikon COOLPIX L2 Digital Camera
Lens stuck
I just wrote a warning about these "telescoping lens" cameras, You need to get the lens back on track. maybe steady pressure, applied to the back of the camera with the lens on a towel on a table to ensure it remains parallel to the camera body.
May 12, 2008 | Nikon Coolpix L11 Digital Camera
Lens error 25 and 15
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 25, 2008 | Kodak EasyShare C330 Digital Camera
Lens error
your lens are stuck! did you drop the camera? you need to get a repair on the lens
Jan 10, 2008 | Nikon COOLPIX L3 Digital Camera
Polaroid i733LP Digital Camera Logo
108 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
