Question about RCA 20V500T 20" TV
Rca20v500t tv
  • carsalesman1 Jan 21, 2008
    Problem Solver:
  • 22 Answers
Try ManualsParadise .com.
Posted on Aug 27, 2008
Picture went all green,what happened?
Check the video output card for any loose solder terminals. Re-solder all the suspected solder terminals. This card can be located at the neck of the picture tube, directly plugged on to its back of the neck.
Aug 19, 2012 | RCA TruFlat 27F520T 27" TV
TV screen stays bleu and dos change to normal raster
Check for any loose soder terminals at the video output card. This card can be located on the neck of the picture tube, directly pluged into it.
Apr 11, 2012 | Televison & Video
Our 21" panasonic television is when turned on,
It is due the fault of its picture tube base socket. Picutre tube base socket can be located at the picture tube card connected at the neck of the picture tube. It is the socket that connects the picture tube pins to the circuit. It can be resoldered out and can be replaced.
Open your tv. Locate the picture tube base card, can be seen connected to the picture tube neck. It is pluged on to the picutr tube, and can be pulled out of it. Be sure not to make any tilt of shake while pulling it out. Just pull it back straight, may have to apply some backward pulling pressure. Resolder it out for the board and go for a same type and number. It can be available at most of the electronc sparepart shops. Replacing it will solve your TVs problem. OK
If you need furthermore asistance, feel free to get me through Fixya.
Dec 22, 2010 | Panasonic TX-29S90X TV
Turn tv on the the morning has sound but no pic until tv warms up (about 15-30 mins)
Your TV has CRT socket problem. This is due to the improper contact of that socket to TVs picture tube. All TVs picture tube [otherwise says as CRT means Cathode Ray Tube] is connected with the remaining control circuit wia a picture tube base card, which can be located at the extreme back side of the picture tube. It is plughed in to it via a socket, and that socket is directly soldered to the base card. The socket mentioned above is faulty. This fault will be more at rainy and winter seasons. During these seasons, your tv will take more and more time to display picture. Because, during this seasons, humidity in the atmosphere is high.
Here replacing that CRT Socket is the only remdey. For that you have to open the back cover of your tv. Locate the base card, can be seen at the back of the picture tube neck plugged in. Unplug it with care, not to damage the picture tube neck or its pins. Do not apply high pressur or sudden jerks. It may break the neck of the picture tube as it is very tender with respect to the other parts of the picture tube.
Desolder the socket from the base board, it may have 9 to 12 connections to be desoldered. Take it out, and go for the same type number and pin confugaration. Replace it with the new one.
NB: Keep children away from you when you do this work. Be sure to unplug the TVs power chord from the wall socket before attempting to open it. Keep out all the connections to the tv, and make it idle. Ok
Oct 19, 2010 | RCA F27442 27" TV
Sound no pic. after on for 20min then turned off back on and pic. now it will not get pic just sound
Your TVs CRT socket is faulty. CRT socket is one that connect the base of the picture tube, and can be located on the base card of the tv. It is soldered directly to base card and can be replaced. Unplug the base card from the picture tube neck [Caution: never damage the neck of the picture tube. Only slight pressure should be applied], desolder it out and replace it with a similar type.
Oct 16, 2010 | Norcent Technologies2703 27" TV
Color of picture on all channels in yellowish
Your optical block, also known as a light engine, is going out. I actually just had mine replaced today!!!!
Dec 11, 2009 | Televison & Video
Picture has way too much green. Can't seem to adjust
Ur video board that connected to the CRT) tv tube with long neck,that board have burn capacitors or something else.U know how to solders?Sometime u get lucky,not burn parts,by taping the board see if it flicker,than it just cold solders,require resoldering.
Oct 22, 2009 | Sony KV-36FV16 36" TV
Tv screen shows green/pink
Ur video board that connected to the CRT long neck(tv tube).Have burn,capacitors?Or cold solder socket pins connected to the crt tube,must resolder,might solved prob.
Oct 14, 2009 | Televison & Video
Green screen
if it is "C514" it is capacitor. maybe the green section from the crt board is dead, try to test the transistor from its circuit or resolder it.
Jan 18, 2008 | RCA 20V500T 20" TV
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
