Question about Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver
My 8130 blackberry pearl keeps losing the radio
My Blackberry 8130 pearl keeps losing the radio signal and I have to click the "manage connections" icon and turn the radio signal on again. Does anyone know how to correct this problem? I don't lose my bluetooth connection/signal.
How to Unlock Blackberry Pearl 8120?
Instructions for unlocking Blackberry Pearl 8120
1. Ensure a SIM Card is inserted
2. Go to 'Manage Connections'
3. Click on 'Turn All Connections Off'
4. Go to 'Options'
5. Click on 'Advanced Options'
6. Click on 'SIM Card'
7. Type 'MEPPD' (letters will not appear on-screen but a menu will pop up.)
8. Type 'MEPP2' (*Note- for Telus, use MEPP4. You will be prompted to enter MEP code)
9. Enter the unlock code (CONFIRM you get "Code Accepted" message)
10. Reboot device
11. Go to 'Manage Connections'
12. Click on 'Restore Connections'
13. Device is now unlocked
http://unlockgenie.com/Unlock-Blackberry-Pearl%208120
Jan 28, 2011 | RIM OEM Blackberry Pearl 8120 8130 Flexi...
Radio keeps turning off on pearl 8130 tryed battery reset but still turning off like every minute or less
This is a device issue. You will need to contact your service provider for replacement options!
Mar 06, 2010 | Verizon Communications BlackBerry Pearl...
My blackberry pearl keeps freezing up and its only 3months old
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Jan 12, 2010 | RIM BlackBerry Pearl 8130 Cellular Phone
Radio signal keeps shuttin off every few secons on my 8130 blackberry
it because of phone reciever get it fixed...........it's a hardware problem
Nov 15, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Blackberry Pearl Radio Issues
First check your settings (In device options make sure auto is off). If that doesn't work you may want to replace the operating system with the most current. You need a PC or laptop and the most recent versions of Blackberry Desktop manager and your phones software.There are instructions at www.blackberry.com/support search for KB03901
Aug 30, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Blackberry pearl 8130 flashed to cricket wont connect to internet
You can call cricket and ask them to "refresh" your internet, wait 5 minutes and try again. Worked for me.
Aug 26, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
I keep on losing the mobile connection
1.There might be temporary network congestion from the service provider end .......Check in different area and handset ......If there is no problem when tried in different handset ...
2.Install Blackberry desktop Manager ...Take Backup..
Reinstall the Software ....
3.if still not happening contact service center as there might be any hardware problem.
Aug 12, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Radio keeps shutting off
When there is no signal around ur blackberry will shut off the radio instead of constantly searching for one which really kills battery power just make sure you arent in a real signal dead area and you should be fine to turn it back on just go to manage connections and click it back on,if this is not the problem then there might be some problem with ur phone.
Jul 12, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
RADIO KEEPS GOING OFF ON BLACKBERRY PEARL
This is acutaly a feature on the phone when there is no signal around it will shut off the radio instead of constantly searching for one which really kills battery power just make sure you arent in a real signal dead area and you should be fine to turn it back on just go to manage connections and click it back on. Now if this isn't exactly the problem you are having then it could be your phone or your network I would call up your network first though to see if they are having problems in your area.
Kyle
Jul 09, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Dropped blackberry 8130 phone will vibrate if called but no screen and buttons are not working
Hi
probably you have 1 broken keypad ic on your 8130 or some broken soldering because of impact. best advise i would be able to give you is for you to find a proper blackberry repair centre like www.E-Repairs.co.uk and get your unit check
Thanks
Jun 11, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Verizon Communications BlackBerry Pearl 8130 Cell Phone - Silver Logo
788 people viewed this question
Top Verizon Communications Cell Phones Experts
ismael castillo
Laxman Bisht
Laxman Bisht
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
