Question about Bosch WFMC 3200 Front Load Washer
Bosch dryer nexxt 500 (wtmc3521uc) broker plastic window
I didn't realize when I accepted shippment the the plastic window in the door was broken. Can just the window be replaced or do I need a new door??
  • Jeff G Jan 24, 2008
    I posted this under washer by mistake but it is a dryer. It looks like your comments hold true for the dryer as well. Do you know where I might find a parts diagram for this dryer?
    THANKS FOR THE HELP!
  • Anonymous Mar 16, 2014
    Does Bosch offer a replacement plastic window for WTMC3321US/05
  • 139 Answers
The plastic window can be repalced you dont need to get a new door...
Just remove the door from the washing machine and undue the screws around the rim and unclp the plastic rim and you should be able to fit in a new one with no problem...
hope it helps any questions dont hesitate to ask..
Posted on Jan 21, 2008
Need to replace the foam strip that seals the front door on my Bosch 500 Nexxt series electric dryer....do I do this from the front?
Most likely yes. Get a good adhesive for it though and make sure it is dry before you close the door and before you use it.
Aug 12, 2013 | Bosch Nexxt 500 Dryer
I NEED SERVICE MANUAL FOR BOSCH NEXXT 500 GAS DRYER
Hi.
I am sorry but unfortunately I could not find the manual for Nexxt 500 gas dryer in my database. The full model number may help me to find the file more than the model name.
A manual for Bosch gas dryer is available in this forum. Subscription to the forum is free: http://applianceguru.com/view_topic.php?id=21241&forum_id=19
When you ask for the manual always include the full model number(e.g.WTMC332SUS ). There are different Nexxt 500 models.
Regards.
G.
Nov 24, 2011 | Bosch Nexxt 500 Dryer
Trying to locate the ignitor on a bosch nexxt dryer..........looking through the round hole on the bottom left.....haven't found it yet. any help? tx
Welcome to FixYa.
The ignitor and burner assembly/burner tube are accessible from the rear and the rear panel must be removed.
i.e.
Once that has been removed, you'll need to remove the rear drum support & drum.
i.e.
Then you can pull the drum assembly out...Now you should see the motor and burner components. The ignitor is partially hidden via the burner tube, but is pointed out in the image below.
Hope that helps you identify and access the ignitor for your Bosch WTMC dryer, good luck.
Regards,
Macmarkus :)
Feb 17, 2011 | Bosch Nexxt WTMC3521UC Gas Dryer
Dryer won't heat
The problem is the ignitor...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 10, 2010 | Bosch Nexxt WTMC3521UC Gas Dryer
Why does dryer stop when the clothing is still damp?
I`m assuming you have not received any error code from the dryer since you didn`t mention that, but would I be correct ?
Have you tried both timed dry and auto dry settings ? If this happening in both setting`s it will help narrow down what to look for.
Are the cloth`s typically spun out really well by the washer ( and is it a Bosch Nexxt as well ) before entering the dryer ?
I will watch for your response in this post and hopefully I`ll be able to help find an acceptable solution for you.
macmarkus :)
Apr 08, 2010 | Bosch Nexxt 500 Dryer
Kenmore 110.74832400 gas dryer doesn't start
take off the back panel and look down by the motor next to the drum belt there should be a black piece of plastic with springs on either side push it to the left and then try your dryer.alos check your door switch
Mar 16, 2010 | Bosch Nexxt WTMC3521UC Gas Dryer
Is it possible to reverse the doors on a Bosch Nexxt 500 series dryer? If yes, does it require a kit from Bosch?
yes ,it is possible,you don't require a kit from bosch,however,you will need to disassemble the machine.if you are not confident,get someone who is.
Oct 16, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch WFMC 3200 Front Load Washer Logo
426 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
