Question about Panasonic Lumix DMC-FZ7 Digital Camera
Says memory card error please check the card - Panasonic Lumix DMC-FZ7 Digital Camera
    Sergeant:
  • 249 Answers
Are you using a new SD card?I believe there is a 2GB max. Use an appropriate card and check that the directory structure is correct on your PC. You should see a DCIM folder containing one or more nnn_PANA subdirectories that contain the pictures. If not your card has not been recognized and initialized.
Posted on Dec 13, 2009
Testimonial: "Thanks I was trying to feed a 4gb in. So now I know that there is a 2gb Max. You have saved me searching further for the solution. So MERRY XMAS!!!"
  • Panasonic Master
  • 13,433 Answers
Hi
Often with new cards the issue is that the card is not formatted.
Please read my guide on the error,
http://www.fixya.com/support/r3671823-solve_memory_card_error_card_error
Thanks,
Ekse
Posted on Dec 19, 2009
alfa104
  • 78 Answers
SOURCE: 16G Memory Gets "Memory card Error Please Check Memory Card"
Iam sorrie but try a other sd card and it will work..
Posted on Jun 19, 2009
  • 11967 Answers
SOURCE: memory card error
You need to format the card in the camera before it will work properly.
Posted on Aug 12, 2009
  • 11967 Answers
SOURCE: My Panasonic Lumix DMC-FZ7 will not read memory
It wants you to format the card in the camera. This will erase the card so download any pictures on it first using a card reader if necessart.
Posted on Oct 14, 2009
t00nz
  • 4738 Answers
SOURCE: camera wont read memory card
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Nov 17, 2010
lock123
  • 6831 Answers
SOURCE: Memory caed error please check the card
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Nov 23, 2010
Memory card error for the Panasonic DMC-TZ1
What type and size memory cards? The DMC-TZ1 works with SD cards 2GB and smaller. It will not work with higher-capacity SDHC cards.
Mar 15, 2013 | Panasonic Lumix DMC-TZ1 Digital Camera
Each time i put my memory car in my phone that is a blackberry 9000 i get a message saying " A media card has been inserted that contains errors. To correct the errors please use a disk error-checking...
Hello.
To do that, you need a card reader. Insert your memory card into a card reader, then:
Insert the card reader into your computer's empty USB slot.
Go to "computer" or "my computer".
Right click on the drive of your card reader and choose properties.
Click the "Tools" tab then click "Check now"
Check "Automatically fix errors" and "Scan for and attempt to recover bad sectors"
Click "start" and wait for it to finish.
That should fix the errors. If it doesn't, format your memory card.
Thanks for using Fixya!
Jun 22, 2011 | Cameras
My s760 samsung indicating card error when taking photo
Please check your memory card for space capacity available. May be your memory card is almost full that preventing you to save the photos. If you have enough space but card still error . please check your card for malfunction. Just try using another memory card to find the problem,
Regards, jay
Dec 25, 2010 | Cameras
When I put the memory card in and turn on the camera, it keeps saying memory card error.
If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
Mar 03, 2010 | Canon Power-shot S1 IS Lens Converter
When i turn the camera on it says memory ard error
Mar 01, 2010 | Optics
Memory card error
Aug 12, 2009 | Leica D-lux 3 Digital Camera
Sandisk error problem
From a command prompt run the following on the drive
chkdsk g: /f
where g: is the drive letter of the usb drive
Apr 27, 2009 | SanDisk Memory Media
You may try to format the memory card and then try again. If needed, you can use a camera photo recovery tool to recover photos from memory card.
Card Recovery Software Free Download
Apr 10, 2009 | Panasonic DMC-TZ5 Digital Camera
Memory card camera wont accept just getting card error,
Please format memory card by going to camera Menu options in
DZ-BX35E and try.
If problem still exist, then memory card slot could be damaged.
Check new memory card in other camera to verify that card is OK.
Dec 14, 2008 | Hitachi DZBX35A DVD Camcorder
Regarding Memory Parity check
this error is usually associated with bad memory cards......how much amount of memory are you using.....try reseating the memory cards(ram)....if you still get the error msg....try starting the system with jst 1 memory (if thr are 2 memory cards installd) & thn swap it with the other one......
Jul 18, 2008 | Lenovo ThinkPad T61 Notebook
Panasonic Lumix DMC-FZ7 Digital Camera Logo
1,532 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
