Question about LG HBM 730 Bluetooth Headset Wireless Headset
Can't Pair With Phone
I had previously paired my headset with my Treo 650 and everything was working fine. Then a couple of days ago my phone would disconnect from my bluetooth in the middle of a call. Now, for whatever reason, my phone won't connect to my headset at all. I tried to re-pair the phone and the headset and that did not work either.
I had the same thing happen twice just recently and had to call my network and have them walk through some steps over the phone with me. They had to have me enter some numbers they gave me while talking to them and it came on. Be sure to call from a different phone than the one you are having the problem with. I also had it happen again a few weeks ago and I just removed the battery from my cell after disconnecting the bluetooth and then when I put it back together and reconnected the bluetooth it worked fine. I have had it for over a year and never had any trouble with it until this.
Posted on Jan 20, 2008
Unable to pair Blueaction Wireless Headset BAE-825 with iPhone, and I cannot locate a user manual, either.
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 13, 2010 | MyNetDeals BlueAction Wireless Bluetooth...
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
No sound on headset even though it has been appropriately paired to my Treo
I too faced exactly the same problem..My phone was the Nokia N70...I too thought initially this was a problem with the headset...But when I had my phone re-started, then the headset started working fine...So I think this problem is related to the phone...Try this out...All the best!
Jun 19, 2008 | Motorola Mobility H350 Wireless Headset
Motorola h700c
Have you tried a soft reset of the unit?
Try uninstall and install again the devices/
Mar 16, 2008 | Motorola Mobility Bluetooth...
Bluetooth problem
try resetting the phone and pairing the device again and see if that helps.
Mar 12, 2008 | Motorola Mobility RAZR V3
LG HBM-730 Won't Connect to Treo 650
Actually it's a Treo 680. Finally took the battery out of the phone. That seemed to clear everything so that I pair the bluetooth with no problem.
Feb 22, 2008 | LG HBM-730 Wireless Headset
Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Jan 11, 2008 | Motorola Mobility Bluetooth...
Paired with old phone, can't pair with new phone.
have ya phone ready to almost pair. Then on the 850 ear piece press the call button until lit and then open boom up and press the phone pairing ok button and the 850 should work. waaala!
See how easy that was.
Oct 08, 2007 | Motorola Mobility HS850 Consumer Headset
I had my treo 650 replaced and now i cant pair the two
Go out to and it will give you great directions on how to get your phone paired. I could not get my adapter and adapter to pair. But the website gave me all the manuals and suppor that was needed to get the problem corrected. You should check it out.
Oct 05, 2007 | Jabra BT160 Wireless Headset
Is this compatible with our phone?
this post is quite old but i think i'll answer it...first of all your phone must have bluetooth. to use it you must pair your phone with your bluetooth headset first. Open your bluetooth headset in pair mode and then open your phone bluetooth pair them and they will auto connect after you paired them(usually).
Apr 27, 2007 | Motorola Mobility HS810 Consumer Headset
LG HBM 730 Bluetooth Headset Wireless Headset Logo
62 people viewed this question
Top LG Radio Communications Experts
TO Lady
Mohamed Ismail
Mohamed Ismail
Computer Repairing
Computer Repairing
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
