Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
I need to replace my kitchenaid superba over the oven microwave light bulb. where can i buy a new one and does the existing twist or pop out?
  • KitchenAid Master
  • 9,098 Answers
Your owner's manual should have the part numbers and instructions for replacing them.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
If the manual does not cover it, then it's not designed for the owner to do, you would need to remove the oven from the wall and remove the outer cover.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
Once you get new bulbs in, if they still won't come on, or if they're stuck on, or you have trouble with either fan, the surge of the failing bulb may have damaged the board.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or two.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 13, 2009
Kitchenaide Superba #4450786A unit turns on but will not heat at any setting. What can I do to fix?
Magnetron needs replaced.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Cheaper to buy a new Microwave oven.
Jul 11, 2014 | KitchenAid KCMS185J Microwave Oven
Lights under microwave will not come on
When this happens, a lot of the time, it is because the the old bulb burnt up violently or it was unscrewed with the power still on to the unit and if the wires on the bottom of the bulb were twisted together, it probably blew a trace off of the back of the circuit board that supplies power to te bulbs. So either need to find someone to repair the circuit board or buy a new one if you can put it in, if not, need to call a servicer to replace it. But caution, thay are not cheap!!! Always unplug you microwave BEFORE replacing the bulbs!!!!!
Oct 14, 2017 | Frigidaire FMT148GP Microwave Oven
Need to replace microwave light in Kitchenaid #KEMS308SWH02. What do I do? Where do I buy a bulb?
Hi, On most microwaves on the back pannel there is a small lid with a screw. You will have to undo one screw to access the light bulb. Take the bulb with you to compare to the new on. Sold in most hardware and super markets. Good luck.
Jul 24, 2011 | KitchenAid Microwave Ovens
Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Dec 22, 2009 | KitchenAid Microwave Ovens
Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Aug 04, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
How do you replace the lamp in a Kitchenaid Superba microwave convection oven combo? What type of lamp?
open the top cover then you can see the bulb on the right side of the oven, just remove the lamp and replace it by a similar one. you can try to get the lamp from any electrical shop with the same size and same rating.
Jul 14, 2009 | Microwave Ovens
I need to rplace the bulb in the interior of the microwave. It's loose in the top housing.
some of the front(vent) covers have a sliding hook I think you need to push it to the left. You should be able to access the bulb when you get that off.
Jun 01, 2009 | KitchenAid Microwave Ovens
Need new light bulb socket for GE spacemaker mircrowave
The bulbs are glued in at the factory. Unplug the microwave and see if you can remove the base of the bulb from the socket with needle nose pliers. You may have to twist the heck out of the bulb base but it should come out. If you do need a new socket it is available at www.geappliances.com under parts and accessories. Or call 1-800-626-2002 for GE factory parts
Dec 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
LIght bulb burned out
I a Kitchen Aid Buit-in microwave (KEMC308KSS01) with the same problem - light went out. Can you send me the instructions on how to replace the bulb? Thank you! dlhamilton@comcast.net
Jan 23, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
524 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
