Question about Philips HTS3566D/37 Theater System
NO DISC error on Philips HTS3566D.
I am getting the NO disc error on any DVD/CD on my HTS3566D.
I got a new DVD lens cleaning disc and even when I run this (cleaning disc), I am getting the NO Disc error.
Can you pl help resolving this error?
SOURCE:
ThaMp3Doctor
  • 8596 Answers
SOURCE: No Disc
Run a dvd cleaner through system, and try again. If that fails, unplug the HTS from the wall outlet for 10-15 seconds, and replug it. If that fails, it will need to be repaired.
-Tha Mp3 Doctor
Posted on Feb 18, 2008
  • 4 Answers
SOURCE: philips DVP642 DVD Player "No disc" problem
if its still under warranty, do that.
if it's not, try taking it back to the store and asking for a replacement. don't let the floor salesman tell you no. insist on speaking to the manager. my strategy is to: "be polite, appear slightly stupid, and dont take no for an answer" it works 80-90% of the time.
if you cant get anywhere (or dont want to try that route), then you have nothing to lose. open the case and try to clean the mechanism and lens
two screws on either side of the unit, and i think another 4 screws on the back side. this will allow you to pull the top cover off the unit.
clean the mechanism, and clean the lens. you can buy cleaner if you want, but i just use a soft cloth and some "no-streak" type window/glass cleaner (windex)
clean your disks as well. this DVD player seems to be sensitive to scuffs and dust more than some other players. you just have to be persistent.
or you could buy another DVD player. at $60, its really a pretty good deal anyhow.
good luck
Posted on Mar 09, 2008
SOURCE: Philips HTS 6500 not reading my DVD's
I've had my hts 6500/37 for 6 months and it started doing this. I purchased a Philips cleaner, and ran it once and this fixed the problem (for now). I'm not confident that it'll last since I've read so many others are having the same problems. I really didn't think the cleaner would resolve the issue since I assumed it wouldn't read the disc, but I guess the micro-fiber cleaners did their job by just loading the disc. We'll see how it turns out.
Posted on May 18, 2008
onyeobike
  • 70 Answers
SOURCE: Loading Problem
No Disk issues on device players like DVDs are caused by the following problems
Dirty Play Heads (Optical lens)
Bad CDs or scratched CDs on the surface
Non Compatible CD formats such as DVDs that are designed for some geographical regions and play formats
Also low electrical current is a major problem too
Your issue could reside amongst any of these problems
Check your DVD compactible play formats if its compactible with the CD you want to play.
If its compactible, then I suggest you get a CD Cleaner to clean to clean to Lens.
Also check your current output and if low, get a voltage stabilizer
Check the surface of the CD if its scratched and get a replacement.
Posted on May 25, 2009
MNfisherman
  • 11896 Answers
SOURCE: Cleaning Lens
To clean the lens, remove cover, take a cotton swab and dip it in rubbing alcohol and rub cotton swab on lens.
This will clean your lens. If the problem persists after the lens is cleaned, than the laser motor is bad, or the timing is off and will need new mechanism.
Posted on Jun 17, 2009
When I open my Philips DVD player and put in disc it will not load and tells me NO DISC. Please help!
You might want to try using a DVD lens cleaner disc like the Philips CD/DVD Laser Lens Cleaner SVC2330 or SVC2520 or equivalent from many AV accessory vendors to help restore the cleanliness of the player read lens, so that its ability to read discs is restored. These discs have a tiny brush stuck onto the "playing" surface that polishes the lens, when the disc is played as normal. There is often an audio commentary to go with the cleaning.
Sep 13, 2017 | Philips Televison & Video
No disc error dvd on Harman BDS
maybe try cleaning the laser ? with a cotton wool bud and metho
Jul 28, 2013 | Harman Kardon Audio Players & Recorders
When I insert a disc I get a "Disc Error" after
Most DVD players display that kind of error when unable to read data on you disc media. Try other DVD disc if that post the same problem. A new one will test if it is the unit problem or the media disc problem. If it post the same problem on a disc that runs well on other players then your player probably has a dirty lens. You can clean the lens using commercially available DVD lens cleaner on the market.
Jun 14, 2011 | LG DP450 Portable DVDDivX Player
"No Disc" error
try a few things first, the issue is that the disk decoder cannot get the information of the cd lan surface this is due to either a bad laser unit, or a very direct lens. cleaning is simple but if the disk cleaner didn't work you'll have to open the unit and wipe down the lens with alchohal esd safe, get at electronics store. sometimes their are stickt subtsances that get on cd discks and are transfered to the lens when it is reading cause the close proximity to the surface at high rpm's good luck.
Dec 21, 2009 | Zenith XBR716
No disc error video and audio cd works only dvd gets nodisc error
Did you try to test it and play another using another disc?
You may try to clean the optical lens of the unit using a optical disc cleaner available on any electronic shop, it seems that the drive lens is dirty and can't recognize the disc inserted.
Hope this helps.
micro
Jul 19, 2009 | Philips DVP3020 DVD Player
Recently upgraded to Office 2007 - now the CD's won't read.
...maybe there's a dirt in your DVD rom lens...try to cleaning the lens with cleaning disk...if the problem still persist then your DVD lens life time is worn out...
Jul 09, 2009 | Dell Dimension 4700 PC Desktop
LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Apr 29, 2009 | LG LXD5230 System
Disc is not working. Error message No disc
Try cleaning both the disk and the lens of the dvd player. Sometimes even a little bit of dust can make your dvd player go ballistic. Brands like Sony,Philips and LG are very sensitive. If anything else fails, you can take it to a repair shop to find out if the lens isn't cracked or the LED isn't responding while trying to read the disk.
Apr 02, 2009 | Philips DVP3960
Memorex dvd player 2040..disc won't stop spinning!
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD hed cleaning CDs.If still the problem persists, contact near by service center for replacing the faulty Lens.
Mar 13, 2009 | Televison & Video
Disc error when reading dvd
try to clean dvd plaer lens with a lens cleaner...
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Philips HTS3566D/37 Theater System Logo
103 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
