Question about Kenmore Washing Machines
What does ATC stand for on the temperature dial?
I have a 95 grand Cherokee 4.0 the climate control and info center are not working at all, I have lights to the buttons but no display at all. I have checked all fuses everything is good. Whatis wrong
ok why not say drivers demand
here its 86f and hot.
but do you want heat or cold
sounds like ATC auto matic climate control options
where it has a dial for spec. temperature:?
if the display was dead. id check power to it\
12vdc. fuse that look good can in fact be BAD
checked fuses means what.
we use a meter to check them
so if power is present on the display controller
then its bad. if no 12vdc there, the fuse or wires to it bad. for electronics to work ,need power and ground,at least active. see the ATC SELF TEST?
th e book is free see ZJ jeeps. all is there
chapter HVAC.
Chapter 24 , wiring is 8w.
posted 300+ times
here
again
http://jeepdied.com/books.html
Feb 05, 2017 | 1995 Jeep Grand Cherokee
Is the temperature "N" the coldest or "+ "the coldest?
N stands for normal. Usually normal is midrange while + is either colder (for more refrigeration) or warmer (for higher temperature). Check the end of the scale for the word , coldest. There will typically be arrows pointing toward colder/est as well. Best would be to move the dial just one (hopefully an) increment and come back 24 hours later and check for a decrease on the thermometer (yours or the reefers built-in one). If it moves the wrong way (assuming constant ambient temperature) try dialing the other direction. .
Nov 02, 2014 | Refrigerators
How to diagnose a non functing Automatic Temperature Control (ATC)
that will be a dealer service issue.. they can assist with this one..
Dec 23, 2013 | 1994 Chrysler Concorde
Heat blower resistor
If you have manual A/C control, the various blower speeds are determined by a string of resistors and a switch setting
If you have automatic temperature control, the blower gets its power from the ATC power module with speed determined by the ATC control module and the body control module
Oct 07, 2012 | 1997 Chrysler LHS
Heater core
No, you don't have to pull the whole dash board but you have to pull a few panels....here is the steps on how to get to it and remove and replace it:
  1. Disconnect the negative battery cable.
  2. Drain the cooling system and disconnect the heater hoses from the heater core tubes. Plug the hoses and the heater core tubes to prevent coolant leakage.
CAUTION NEVER open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. Also, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
  1. Remove the 3 nuts located below the windshield wiper motor attaching the left end of the plenum to the dash panel. Remove the 1 nut retaining the upper left corner of the evaporator case to the dash panel.
Plenum removal—1990-98 vehicles
  1. Disconnect the vacuum supply hose(s) from the vacuum source. Push the grommet and vacuum supply hose(s) into the passenger compartment.
  2. Remove the right and left lower instrument panel insulators.
  1. On 1989 vehicles:
  2. Remove the 3 glove compartment hinge screws, disconnect the check arms and remove the glove compartment.
  3. Loosen the right door sill plate and remove the right side cowl trim panel.
  4. Remove the bolt attaching the lower right end of the instrument panel to the side cowl.
  5. Remove the instrument panel pad as follows:
    • Remove the 2 screws attaching the pad to the instrument panel at each defroster opening. Be careful not to drop the screws into the defroster openings.
    • Remove the one screw attaching each outboard end of the pad to the instrument panel.
    • On Crown Victoria, remove one pad attaching screw near the upper right corner of the glove compartment door.
    • Remove the 5 screws attaching the lower edge of the pad to the instrument panel. Pull the instrument panel pad rearward and remove it from the vehicle.
  6. On 1990-98 vehicles:
  7. Remove all instrument panel mounting screws and pull the instrument panel back as far as it will go without disconnecting any wiring harnesses.
  8. Make sure the nuts attaching the instrument panel braces to the dash panel are removed.
  9. Loosen the right door sill plate and remove the right side cowl trim panel.
  10. If equipped with manual air conditioning, disengage the temperature control cable housing from the bracket on top of the plenum. Disconnect the cable from the temperature blend door crank arm.
  11. If equipped with Automatic Temperature Control (ATC), proceed as follows:
  12. On 1989 vehicles, disconnect the temperature control cable from the ATC sensor.
  13. Detach the vacuum harness line connector from the ATC sensor harness and detach the electrical connector from the ATC servo connector.
  14. On 1990-98 vehicles, remove the cross body brace and disconnect the wiring harness from the temperature blend door actuator. Detach the ATC sensor tube from the evaporator case connector.
  15. Detach the vacuum jumper harness at the multiple vacuum connector near the floor air distribution duct.
  16. Disconnect the white vacuum hose from the outside-recirculating door vacuum motor.
Floor air distribution duct removal—1990-98 vehicles
  1. Remove the 2 hush panels.
  2. Remove 1 plastic push fastener retaining the floor air distribution duct to the left end of the plenum.
  3. Remove the left screw and loosen the right screw on the rear face of the plenum and remove the floor air distribution duct.
  4. Remove the 2 nuts from the 2 studs along the lower flange of the plenum.
Heater core removal—1990-98 vehicles
  1. Carefully move the plenum rearward to allow the heater core tubes and the stud at the top of the plenum to clear the holes in the dash panel. Remove the plenum from the vehicle by rotating the top of the plenum forward, down and out from under the instrument panel. Carefully pull the lower edge of the instrument panel rearward, as necessary, while rolling the plenum from behind the instrument panel.
  2. On 1989 vehicles with ATC, remove the ATC servo from the plenum.
  3. Remove the 4 retaining screws from the heater core cover and remove the cover from the plenum assembly.
  4. Pull the heater core and seal assembly from the plenum assembly.
To install:
  1. Carefully install the heater core and seal assembly into the plenum assembly. Visually check to ensure that the core seal is properly positioned. Position the heater core cover and install the 4 retaining screws.
  2. On 1989 vehicles with ATC, install the ATC servo on the plenum.
  3. Route the vacuum supply hose through the dash panel and seat the grommet in the opening.
  4. Position the plenum under the instrument panel with the register duct opening up and the heater core tubes down. Rotate the plenum up behind the instrument panel and position the plenum to the dash panel. Insert the heater core tubes and mounting studs through their respective holes in the dash panel and the evaporator case.
  5. Install the 3 nuts on the studs along the lower flange and one on the upper flange of the plenum. Install the 3 nuts below the windshield wiper motor to attach the left end of the plenum to the dash panel and the one nut to retain the upper left corner of the evaporator case to the dash panel.
  6. Position the floor air distribution duct on the plenum. Install the 2 screws and plastic push fastener. If removed, position the panel door vacuum motor to the mounting bracket and install the 2 attaching screws.
  7. Connect the white vacuum hose to the outside-recirculating door vacuum motor. Attach the vacuum jumper harness to the plenum harness at the multiple vacuum connector near the floor air distribution duct. Install the floor duct.
  8. If equipped with manual air conditioning, connect the temperature control cable housing to the bracket on top of the plenum and connect the temperature control cable to the temperature blend door crank arm. Adjust the temperature cable.
  9. If equipped with ATC, proceed as follows:
    1. On 1989 vehicles, connect the temperature control cable to the ATC sensor and adjust the cable. Route and attach the vacuum harness connector to the ATC sensor and attach the electrical connector to the ATC servo connector. Do not block the sensor aspirator exhaust port with the excess vacuum harness. Install the ATC sensor tube between the sensor and the evaporator connector.
    2. On 1990-98 vehicles, attach the ATC sensor tube to the evaporator case connector. Install the cross body brace and connect the wiring harness to the blend door actuator.
  10. Install the bolt to attach the lower right end of the instrument panel to the side cowl. Install the right side cowl trim panel and tighten the right door sill plate attaching screws.
  11. On 1989 vehicles, install the instrument panel pad and the glove compartment door. On 1990-98 vehicles, push the instrument panel back into position and install all instrument panel mounting screws. Install the right and left lower instrument panel insulators.
  12. Connect the vacuum supply hose(s) to the vacuum source.
  13. Install the right and left lower instrument panel insulators and install the 2 hush panels.
  14. Unplug the heater core tubes and the heater hoses and connect the heater hoses to the heater core tubes. Fill the cooling system.
  15. Connect the negative battery cable and check the system for proper operation.
Feb 15, 2010 | 1993 Ford Crown Victoria
Kenmore 600 with atc. water temp change
to change water temp when a cycle has started, pull the knob and reset the water temp, then move the dial to the desired setting. push knob in. resolved by trial and error!
Nov 05, 2009 | Maytag MAV5920E Top Load Washer
Whirlpool top loader: very loud pumping sounds when filling
You are experiencing surge pressure due to the ATC. It is increasing then reducing the hot water slow to maintain a pre-determined temperature.
I am not aware of a disable or bypass procedure.
Sep 05, 2009 | Kenmore 22422 Top Load Washer
The car keeps coming up a code 23 on a 1999 chrysler 300 for the
Code 23= Blend door feedback control
On cars with automatic climate control: To enter diagnostic mode, set the temperature to 75F, press the the off button. Press Floor, Defrost\Floor, Front Defrost simutaneously for 3 seconds until the temperature display begins to flash.
On cars without automatic climate control, set the blower to any speed, turn the temperature control in between warm and cold. Press Floor, Defrost\Floor, and Front Defrost. All codes will flash via the Front Defrost button.
When the test is over all fault codes will be displayed (on cars without automatic climate control, they will be blinked out on the Front Defrost button).
Code Action
23 Blend door feedback control
24 ATC mode door feedback failure
25 Ambient temperture sensor failure
26 ATC in-car sensor
27 Sun sensor failure
31 ATC recirculate door stall failure
32 ATC blend door failure
33 ATC mode door stall failure
34 Engine temperture sense failure
35 Evap temperature sense failure
36 ATC head command failure
Mar 23, 2009 | 1999 Chrysler 300M
Washing Machines Logo
187 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
