Question about LG Flatron L1750S 17" LCD Monitor
My LG Flatron L1750S when powered on blinks and then goes out. I have switched over to two other machines (pc's) and the problem follows. Please help me I can afford to buy another monitor right now. Thanks
  • 732 Answers
Melrosebanjo, Your monitor will need to have some work done on it's "switch-mode-power-supply" and /or "INVERTER" circuit. After you view some vids at YOUTUBE that deal with replacing bad electrolytic filter capacitors and detecting poor quality intermittant solder joints. Search for vids of "LCD monitor repair" "LCD monitor disassembly" !! Learn what are the major causes of LCD BLACK screen problems. Learn the difference between BLACK AND BLANK screens. Read some of my other posts in my profile. then repost with additional comment here on fixya. also visit www.ccl-la.com/badcaps.htm. and www.lcdparts.com
www.badcaps.net FYI Good luck 12fixlouie
Posted on Dec 13, 2009
My LG Flatron L1750S will not come out of "power saving mode" any ideas on how I can fix this problem?
Try it with another PC first, if still not working, then start looking at the power supply DC filter caps first.
http://s807.photobucket.com/albums/yy352/budm/LG%20L1751S/
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Aug 31, 2010 | LG Flatron L1750S 17" LCD Monitor
LG Flatron - green power led blinks twice
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 21, 2010 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
LG Flatron monitor
Hi...there,
In power saving mode to preventing further damaged to you monitor. You've got a busted backlight inverter that need to be replaced. Happy Holidays!
Nov 06, 2008 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L1750S LCD won't display anything...
To your concern, a couple of suggestions:
  • if you could try again a reputable electronics service center/shop, pls mention for them to look at the CCF (cold cathode florescent) lamps, the inverter and/or the main board;
  • the blinking light is significant, it could indicate loss of video signal or internal protection kicking in;
  • possibly heat related, check for any of the capacitors bulging or leaking.
If they would reference a service manual or a schematic diagram, pls relay that it is chassis CL-82 for an LG L1750S. Foremost to check would be for the presence of both the 12 and 5 volts,.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 22, 2008 | LG Flatron L1750S 17" LCD Monitor
L1750s 17"
This problem is showing when the main PCB of the monitor failed. contact the LG service provider in your area. Here is the link to get the service center info
http://www.lgservice.com/
Dec 31, 2007 | LG Flatron L1750S 17" LCD Monitor
Flatron L1719S
I think your monitor is unstable. Is it showing power saving when you boot your PC? Does it show something when the Windows XP splash appears?
Jun 05, 2007 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
309 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
