Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Brush does not move - Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
  • 701 Answers
You need to replace the belts. Here is a link to the replacement belts you need:
Dyson DC14 Belts
Posted on Dec 13, 2009
My brush stopped spinning, but instead makes a loud plastic grinding noise.
Both ends of the brush roll should spin freely. You need to replace the brush roll.
Jan 21, 2014 | Hoover SH40060: Multi-Cyclonic Canister
Brush doesn't move
Your belt is broken and needs to be replaced. Turn this brush side up. Unscrew the cover plate and you will see where the belt goes. Pull out roller, put on new belt, put back together and there you go.
Oct 07, 2012 | Euro-Pro NV22 Shark Navigator Bagless...
Dyson DC 14 Animal - The carpet brush does not turn. I cleaned thoroughly per the instructions but the brush does not turn. I tried moving the carpet/bare floors switch with the same results - carpet...
The brush will only spin when the machine is reclined. Not when the machine is stood upright.
If the brush doesn't turn when the machine is reclined, and the brush control set to "auto", you have a brush bar and/or belt problem.
Jan 18, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
THE ROLLER BRUSH WILL NOT TURN. I PUT ON A NEW BELT AND IT BROKE IMMEDIATELY. THE ROD THAT HOLDS THE BELT IS MOVING BUT THE BRUSH IS NOT MOVING.
Apparently something is binding the brush, keeping it from turning. Remove any string, hair, etc., that is wrapped around the brush. Removing the brush is the easiest way to do this, then cut the material through at one point.
While the brush is out, check the ends for signs of damage that may cause the brush to bind. Also, check the area the brush connects to.
Reattach the brush and try to spin it. If it spins freely, put your vacuum back together, with another belt, and try again.
If this doesn't work, I suggest a new/different vacuum.
Oct 25, 2010 | Bissell Vacuum - Momentum Cyclonic 1 ea...
My brush roller stopped spinning so I had to take it off and clean out all the hair that had gotten wound around it. I replaces it and now it is make a lound noise, but only when the brush is on. Could it...
Could very well be the belt. When cleaning the brush it is a good idea to add some WD40 at the ends where the plastic pieces are that hold the brush in the vacuum. The brush needs to be able to move freely around the plastic pieces. Add the WD40 and rotate the plastic pieces around the brush until they move freely. Reassemble making sure the belt is put in correctly so the brush moves in the right direction.
Please provide a Thumbs Up if this solution is of help to you. Paul
Oct 10, 2010 | Bissell Upright Vacuum - The Pet Hair...
I have an Oreck XL2 and the brush is not rotating.
First, check to see if the drive belt for the brush is broken. If it is you need to get it replaced. Also, remove the brush from the cleaner and clean if of all debris then check the small caps at both ends of the brush. If they do not move freely, add a little WD40 and rotate by hand until they move freely. When putting the new belt on or replace the old one, be sure it is put on properly so the brush rotates in the right direction.
Sep 15, 2010 | Oreck XL2200 Bagged Upright Vacuum
We have a Hoover Tempo, and the brush stopped moving around. How do you get the brush to move again?
The most probable problem is the belt that runs the brush broke. Purchase a new belt for that model and replace.
Aug 22, 2010 | Hoover Vacuums
The rotating brush is not moving.
is the dyson brush belt-driven like most other vaccuums? broken brush belts usually cause that. they are easily replaced at most dept stoes or vac stores.
Apr 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush not moving in Bissell pro-heat
if the belt is more then 6 months old or more, then the belt will have to be replaced reguardless of the way it lookes. belts can stretch over time and when you put the machine on the carpet the friction causes the brush to stop because the belt has stretched. i would try this first. hope this helps
Jul 30, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Irobot moving slowly
Try running th roomba with the dust bin removed to see if the main brush is turning, if not it could be an issue with the gears being stripped in the brush motor assembly or inside the brush compartment holder. If the gears are fine the brush motor itself may be blown. A new one is about $30.00.
May 01, 2008 | iRobot Roomba Discovery SE Bagless Robotic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
138 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Manchester Vacs
Manchester Vacs
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
