Question about Canon Cameras
I dropped my camera and the lens was attached, in the fall the lens broke off the body. The piece of the lens that attaches to the body was damaged so it will not lock in position. otherwise i think it might still work. how hard is it to replace this part of a canon zoomlens ef 90-300mm 1:4.5-5.6 i see 4 screw at the part that is damaged. is it possible to just replace this part of the lens
    Scholar:
  • 170 Answers
That was a very sad thing to happen. There is no quick fix solution for this. You should take it to an authorized service center. But I fear this is not going to be an inexpensive process. Let them have a look and assess the damages. We have no way of judging what could have happened inside--whether there has been any misalignment of elements or focusing mechanism.
Posted on Dec 13, 2009
Nikon d3000
did you try a different lens if you did send your camera in for repair . the lens gets damaged easy
Feb 07, 2013 | Nikon D3000 Digital Camera
Broken lens contact...Can't find replacement part
You may order the lens mount assembly or just the lens mount from here.
Nov 26, 2012 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
No image was shown on screen while i still can take photo.
According to ehow:
Turn off your Canon 1000D and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • Place the body cap on your camera to keep dust out. Attach the front and back lens caps on your lens to prevent scratches and other damage.
  • Let the camera sit for 20 minutes. This will clear the camera's memory.
  • Place the date/time secondary battery and a fully charged primary battery in the camera and turn it on.
  • Press the shutter release button (the button you push to take a picture). If you are still receiving an Error 99, the problem is most likely caused by the camera body itself. The camera body must be serviced by a professional camera technician.
  • Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • Turn off the camera and reattach the lens. Turn on the camera and press the shutter release button. If you receive an Error 99, turn the camera off and remove the lens.
  • Turn the camera so that it is face down, and gently clean the lens contacts on the camera body with a number 2 pencil eraser or soft cloth. The lens contacts are the eight small, gold pieces on the bottom of the lens mount. Be careful not to let any of the eraser scraps fall into the camera body.
  • Turn the lens so that the side that attaches to the camera is upside down. Use the eraser or soft cloth to clean the lens contacts on the lens, being careful not to let any eraser scraps fall into the lens.
  • Reattach the lens to the camera. Turn on the camera and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the lens. Take the lens to a professional camera technician for repair.
  • May 11, 2011 | Panasonic Lumix DMC-FS4 Digital Camera
    Every time I turn on the camera it sais Error 99 could anyone explain it to me .thanks chris
    According to ehow:
    Turn off your camera and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • 6 Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • May 11, 2011 | Cameras
    Dropped my canon eos350d with 18-55m lens. where the lens attaches to the camera is broken ie the casing along the edge that connects to the camera, hence light is getting in and camera is not functioning...
    I'm trying to read this correctly, is it the lens that is cracked or the camera/camera body mount?
    If it is just the lens you may find it less expensive to purchase a new lens the 18-55mm is a kit lens and fairly inexpensive to purchase over repairing one. If it is the camera I'm not sure what to suggest and the repair would be very expensive to replace the chassis outer body.
    Jan 18, 2011 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
    I dropped my Nikon d50 and now when I turn it on it flashes fEE. Whats wrong?
    The lens is not making proper contact with the camera. Try removing the lens, cleaning the contacts on both the back of the lens and in the lens mount on the body, then reattaching the lens. If that doesn't do it, try jiggling the lens gently. If that doesn't do it, try attaching a different lens if you have one available, or attaching the lens to a different body if that is possible. If nothing works then it could be that the lens and/or camera needs servicing after the drop.
    Apr 25, 2010 | Nikon D50 Digital Camera
    Nikon AF 35-135 lens
    Did the only the lens drop or was the lens attached to the camera body? If the lens was attached to the camera, you need to verify that the problem is in fact the lens and not the camera body. The easiest way to do that is to try a different lens on your camera body or your lens on a different body. If you do not have access to either, I would find a local camera store that sells Nikon equipment. I am sure they will let you put your lens on one of there bodies. In any case, ff the damage is as extensive as it sounds from your brief description, you need to take it to a camera repair man. This is not a do-it-yourself job.
    Feb 07, 2009 | Nikon N70 35mm SLR Camera
    18-55mm lens won't zoom
    DON'T TRY TO FIX THIS YOURSELF! You will only add to the damage. If your lens is in warranty, contact Nikon for instructions to get it repaired. If it is out of warranty, I would either pay Nikon for the repair or take it to a camera repair man.
    Dec 27, 2008 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
    Lens not attached
    Is there a piece of tape across the lens contacts, like the film over a print cartridge head? I would think that is the only communication between the lens and the body.
    Jun 06, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
    Digital dsc F707 problem
    I used Super Glue and my camer ia stil working.  However you need to be very careful taht no glue gets onto the lens itself as it cannot come off and will give your pictures a blurred effect
    Sep 11, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
    Cameras Logo
    74 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
