Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
The washer will come on for a short amount of time, sometimes only if you hold the power button. the it says a de notification
  • dlehman237 Dec 14, 2009
    Very Helpful thank you
  • 11,896 Answers
Sounds like either your power supply or control board is faulty. You will have to do some testing with an ohmmeter and a voltmeter and test power from supply to main control board. And from control board to motor and from and to start button to make sure it is not the start button itself that is faulty. If you have a bad water level sensor, the water will start filling for a while and end up quitting on you.
Posted on Dec 12, 2009
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
My computer wont always turn and it shuts down on its own it desplays a blue screen an also it keeps tellin me to reseat the memorey
Here are the instructions for re-seating the memory:
http://support.dell.com/support/edocs/systems/ins1525/en/SM/memory.htm#wp1181008
make sure that power and battery are disconnected and hold power button for 10 seconds to discharge any stored power before opening system to re-seat the memory.
If you have 2 memory modules, you might try re-seating 1st if issues still occur, then try the modules one at a time. You will also get bios notifications of amount of memory changing, just press F2 to enter BIOS then exit to clear the error any time the amount of RAM in the system is reduced or inscreased.
Jul 17, 2011 | Dell Inspiron 1525 Notebook
Hi, my bb9000 consumes battery very fast please advice what should i do in this regard?
Instructions
    • 1 Turn off your wireless and Bluetooth when they are not in use. If you leave your wireless settings on, your phone is constantly looking for a wireless connection, even if one isn't readily available. This eats up battery power. Touch "Manage Connections" from your home screen and select "Off" for wireless connection. Then turn your wireless on when you know a connection is available.
    • 2 Close applications when you're finished using them. Leaving applications running uses memory and battery power, especially if those applications send you frequent notifications, like Facebook. Once you're done using an application, use the Blackberry button and select "Close" at the bottom of the menu to close the app completely and avoid notifications until you open the app again.
    • 3 Use your applications wisely. If you're running short on battery life, it may not be a good time to run Google Maps or other applications that use a lot of battery power. In general, battery-consuming applications are those the need a constant internet or data connection and cause you to receive frequent notifications.
    • 4 Change your vibrate notifications so that they occur less frequently, and use audio notifications when you can. Vibration actually uses more battery life than a ring tone. While you may need to put your phone on vibrate when you need to use your phone discreetly, shortening the amount of vibration notifications you get can conserve battery life. Choose "Options" from your home screen, and then "Sounds and Ringtones." Choose "Ringtones" from the drop down menu and select the type of ringtone you want. To decrease the volume of your vibration -- and therefore the power you use -- press the volume buttons on the side of the phone when the phone is in vibrate mode.
    • 5 Decrease the backlight timeout, which keeps the keys on your Bold lit for a specified amount of time after you stop using them. The shorter the timeout, the less battery power you'll waste. Visit "Options" from your home screen and then choose "Screen/Keyboard." Adjust the backlight settings so you only have three to five second before timeout and the backlight shuts off. You can also use the settings to dim the backlight to use less power.
Read more: How to Optimize My Blackberry Bold's Battery Life ' eHow.com http://www.ehow.com/how_8087565_optimize-blackberry-bolds-battery-life.html#ixzz1HLj9WRhr
Mar 22, 2011 | RIM BlackBerry Bold 9000 Smartphone
The washer will not begin. After you push the start button, you can hear the door latch click to lock. After a few seconds, the screen flashes dE.
Is that one of them new fancy self cleaning washer ranges?
Cleans the stove and the clothes at the same time?
IE: Water level
UE: Imbalance
OE: Drain problem
FE: Overflow
PE: pressure sensor
dE: door error
LE (with a a slash in the
middle of L. Thermister out
CE: Over amping
LE: hall sensor short
bE: Ball sensor loose connection
EE: eeprom out
PF: power failure
More here
Dec 20, 2010 | Kitchen Ranges
How to reset error e4
The reset method work for canon printers that using PG-40 and CL-41 cartridge. After doing this reset method canon printer will not display low ink notification anymore and will not show error code “E4′ or “E5′.
Here How to Disabling Low Ink Level Notification for Canon IP and MP, the method to reset ink level notification:
  1. Push “resume” for 5 seconds for canon IPXXXX. For canon MPXXX you must enter to service mode.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Enter to service mode for canon MPXXX
  • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
  • When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
Apr 15, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Resetter
http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
The reset method work for canon printers that using PG-40 and CL-41 cartridge. After doing thisreset method canon printer will not display low ink notification anymore and will not show error code “E4′ or “E5′. This method takes from indoreset yahoo group and prepared by Choy.
  8. Open cover
http://downloadprinterresetter.blogspot.com/
OK, go to website above, and download a "Resetting" tool, this makes resetting easier to do.
Apr 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Too little volume
Hi
Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
Nov 23, 2009 | Gaggia Syncrony Espresso Machine
How do i make bigger cups of coffee . I push the "large button but the amount of water is for a very small cup of coffee. is there a way to change the water level?
Hi
If that doesn't fix it, then you might need a new flow meter.
Nov 10, 2009 | Saeco Magic De Luxe Espresso Machine
Sometimes,water leaks out from under washer. the amount is cleanable with two large bath towles. Machine is just out of warrantee. Please advise
I suggest that you check the screw holding pump motor to pump, if they get loose water will leak
or check the short hoses from pump, clamps may abe loose
Jan 08, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
18 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
