Question about Kenmore Sewing Machines
Hand wheel wont turn on my Kenmore sewing machine
All of a sudden when I was sewing today, I was pressing my foot control and it sounded like the motor was running really fast but the needle wasn't going up and down. I tried to manually make it with the hand wheel but it won't turn unless I put alot of pressure on it, and even then, it didn't move alot.
  • 96 Answers
It sounds like the belt to turn the wheel broke
Posted on Dec 13, 2009
SOURCE:
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
All of a sudden my Singer Inspiration 4206 stopped working. When I press the foot peddle it only makes a swinging sound like when you're only swing a motorcycle but not driving it. If I turn the hand weel...
If the swinging sound is from the motor, right side just below your hand wheel, possibility your motor belting is loose or broken. If you don't have mechanical skill / experience, suggest to get your local technician to fix it.
Nov 10, 2013 | Singer Inspiration 4206
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
Why do I have to help to start my machine by hand. If I don't push the wheel it just hesitates.
You must always make sure the takeup lever is just on the way down before you press on the foot control, with the takeup lever at the top the thread will be strong enough to hold the machine back.
Oct 26, 2009 | Kenmore 19001
Won't sew when foot pedal is pressed
foot pedals do fail and possibly your s has .
Oct 31, 2017 | Kenmore Sewing Machines
When i press the pedal, the needle wont move and i already oiled the machine
press the hand wheel in. On this machine you pull the hand wheel out to disengage the needle while threading the bobbin and press it back in to reengage the needle.
Jul 11, 2009 | Kenmore 15212 Mechanical Sewing Machine
Janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Feb 25, 2009 | Janome MyLock 634D Mechanical Sewing...
Kenmore foot peddle going too fast to sew
The problem is either in the foot control or there is a short in your wiring. You can replace the foot control and hope that's where the problem is or Take it to a technician to be sure..The foot control will probably cost around $30-$50.
sewman7
Jun 30, 2008 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
775 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
