Question about Raytheon VHF 53 CB Radio
I need a power connector for a Ray 53 radio. It
I need a power connector for a Ray 53 radio. It is a 6 prong connector. I only have the half that attatches to the radio. I also need a metal mounting bracket and the two side screws.
  • 96 Answers
First off for the metal mounts
http://www.cwrelectronics.com/product.php?id=11552
http://www.kenselectronics.com/lists/pwrcord.htm
Posted on Dec 13, 2009
Howw do you make a Samsung bd-F5700 blue ray player operate on a 240 volt power supply
You'll need to bring the voltage down to 110-120 volt. Travel converters do this cheap and effective. The player only uses 12 Watt according to the manual. You could use an old 3 prong extension cord to cut of the connector to connect to your power supply. Get the converter below and plug it into the adapter, who then will fit in the extension cord.
25361686-pcx3svhkvlazjixsdsr3jt1v-2-0.jpg New 220V to 110V Step Down Voltage Converter 50W Travel Power Transformer 25361686-pcx3svhkvlazjixsdsr3jt1v-2-3.jpg Generic Round Europe to USA Plug Adapter
Jan 09, 2015 | Samsung Televison & Video
Need replacement speaker cables for dav-hdx576wf
Since noone else gave you a good answer I will. I lost some cables to mine a while ago and found this awesome jerry rig solution; Go to radio shack, and ask for '14-16 gauge star ring terminal connectors' Should come in a pack of 10 and be about 2$. On the back of the unit where these connectors fit, there should be two prongs. You will need two star-rings for each connector slot. Wire up your connectors and crimp the ends LIGHTLY with a pair of pliers. The star-ring connector connected to the negative wire should be inserted to the left prong, (left if you are facing the back of the unit), and the right prong is the positive. If you did everything correctly, you should be able to make your own wires for sony stereo systems whenever you need to. Saved my ***, hope it did the same for you. Here is a link to what they look like. http://www.shopping.com/radio-shack-non-insulated-crimp-on-star-ring-terminals-10-pack/info
Aug 06, 2012 | Sony BRAVIA® DAV-HDX576WF Theater System...
I need to change the head unit in my 1990 Buick Century, but the wire harness the mechanics gave me doesn't fit?
The connectors for all GM oem radios for this car/year are the same. The place that sold you the new radio should be able to provide a patch cable with a connector at one end that fits the aftermarket radio, and one or more connectors at the other end that fit into the connectors in your car. If you can't get that patch cable from them, try sonicelectronix.com. These cables are usually unique to the brand of your aftermarket radio. Although it's a bit late, It's a good idea to check that these patch cables are available from the seller before buying the radio.
If you can't find a patch cable and the cable that came with the new radio has no connector(s) on one end, you will need to splice those wires to the correct wires going to the old radio connector, and for that you will need the wiring diagram for both your car and the new radio. You should be able to get the wiring schematics for your car from Alldatadiy.com, and your new radio should have come with a connector pinout description.
Mar 08, 2017 | 1990 Buick Century
Need a mike holder for my ray 53 vhf
Go to the Nearest Truck Stop they have many types of Mic holders i am sure one will work for you.
Aug 21, 2010 | Raytheon VHF 53 CB Radio
Need a new mic for TRC447 radio Shack CB. Has a 6 pin connector
Hi Old
here is the link to wire up a different mic look on pg. 51 of this pdf.
link.http://www.cbtricks.com/radios/realistic/trc_447/graphics/trc_447_sm.pdf
hope this helps save this radio from the trash!!!
Ray
Aug 05, 2010 | Radio Shack TRC-447 CB Radio
Jassy 1103, will not start charging the battery.\r...
the 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
May 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Radio width is about 6 inches. Bracket that holds
I use two L brackets myself, you can get them at any hardware store.......hope this was helpful..
Apr 24, 2010 | Raytheon VHF 53 CB Radio
Rci2950keys up but no power gos out
Check to make sure that the radio is on AM not FM or LSB or USB. There is Also a power control on the front of the radio turn it up half way and see if this might be your problem.If it still does not have any power out put,put the radio on usb or lsb make sure that your modulation is turned up and talk into the mike to see if you have any output.If you do have output on ssb mode the am regulator is most likely bad. ( Q 51 & Q 53) wich is located in the right hand side of the radio.
Nov 08, 2008 | Radio Communications
Help need a new mic
I tried to locate one for you on eBay, but had no luck. You best bet would be to go to the Raymarine website, and find a local dealer or contact Raymarine directly. Here is a direct link to their customer support page:
http://www.raymarine.com/Default.aspx?site=1&section=3
I hope this helps, if you need anymore assistance, please dont hessitate to reply here or email me at:
rollincbmods@yahoo.com
Dean Pitts
Rollin CBs
Mt. Vernon, TX
May 21, 2008 | Raytheon VHF 53 CB Radio
Raytheon 80 VHF
Look for harness connectors at St.Vincent DePaul
Mar 17, 2008 | Radio Communications
Raytheon VHF 53 CB Radio Logo
113 people viewed this question
Top Raytheon Radio Communications Experts
Marvin
Marvin
Mike Charette
Are you a Raytheon Radio Communication Expert? Answer questions, earn points and help others
