Question about Samsung SGH-T429 Cellular Phone
My keypad will only work a little - Samsung SGH-T429 Cellular Phone
1200 keypad ic diagram
Did you drop liquid on the phone ? Take out the keypad and let the device and keypad both dry up for a little bit. put them back together and it should work.
Jul 25, 2013 | Cell Phones
Have a new craftsman garage door opener and a new chamberlain keyless entry pad. i cannot get the keyless entry pad to work
As you may know by now there are keypads and then there are keypads. They must be made to work together as there are some that are not compatible. Posting your model numbers might help a little.
Oct 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Keypad entry has quit working
Reinstall your own code,if the preset works and you still have the little instruction card. If not let me know,I'll look at mine and go over the service manuals
Apr 29, 2010 | 2001 Lincoln LS
Schlage electronic keypad lock doesn't work
I have the same/similar problem. I called the company 888 number. The customer rep promised to send me a new one. good luck
Apr 07, 2009 | Schlage BE365-PLY BE365PLY626 Satin...
Reset keyless remote..need directions for 1/2 horsepower sear's b
Ok you need to reset the code on your keypad? Or put a new code in. Well ill tell you how to do both. Before you start make sure you have all the remotes with you. to clear the keypad you have to delete all the codes for all the remotes (No there is no other way :-/) To do this there is a little red button on your opener its self not the remote. Press and hold it till the light goes out.(apox 6-8 sec) Try one of the remote they should not work. Now to set everything back up. Press the red button again just once DONT NOT HOLD IT. a little ambered color light will come on and flash then press the remote untill you hear a click and the lights on the open should flash once. Repaet that for each remote. Ok now to set up your keypad press the red button again go to your keypad and type in your code and hold enter till you see the lights flash on the opener. Then type in your code again to make sure it worked. If you just wanted to program a new code for your keypad then just do that last step
Feb 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad
just open your keypad and clean it wid little spirt wet clothand use it after it dry
Mar 15, 2008 | Samsung SGH-E370 Cellular Phone
KEY PADS NOT FUNCTIONING
Before replacing your keypad, try to open your phone with a star screwdriver, remove the keypad and then place it again, and test if it works. Most of the times this solves such problems.
Oct 09, 2007 | Sony Ericsson V600i Cellular Phone
Driver for Goldtouch 10-Key Numeric Keypad
Might be your USB port. I see USB ports go bad everyday. They are frail little things.
Aug 10, 2007 | Goldtouch 10-Key Numeric Keypad (GTKEYPAD)
Samsung SGH-T429 Cellular Phone Logo
48 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
