Question about Black & Decker ASI300 Air Station Inflator
How do I change the F1 fuse on the B&W Air Station?
  1. Take off the bottom(6 screws philips)look for a small glass fuse that is soldered in place.
  2. Cut this fuse out(cut as close to the fuse as possible)
  3. Replace fuse(1.25amp 250Volt) You can find on e-bay search by 1.25 amp) there is a fuse with the wire already attached on it....solder new fuse in place.
  4. If you dont want to wait to order the fust just solder wire into the fuse area(you will have no surge protection but it may worth the risk because the frequncy if this fuse blowing.
  5. It may look like the fuse is O.K. but trust me its blown.
  6. There are 2 compessor bellows keep in mind they don't both run at the same time One isfor AC the other for DC.
Posted on Mar 24, 2010
Why the fuse burn and the car turn off , I change the fuse and the car turn on again
It sounds like a dead short somewhere in the ignition circuit or the "main" circuit. If everything else on the car dies (lights, chimes, instrument panel, etc) when that fuse blows, that would most likely be the main fuse you've identified. It's going to be a serious pain to find that short, and I'm sorry I don't have any real leads as to what it could be other than tracing the wiring back. Whatever you do, DO NOT replace the fuse with one of higher amperage... The wiring will surely melt or even worse, catch fire!
May 05, 2016 | Suzuki XL7 Cars & Trucks
Air station inflator - catalog #AS1300 - THE owners manual tells of a fuse that may have blown.. if it won't start, where is the fuse, located?
Black & Decker asi300 part 3 - YouTube
? 21:26
www.youtube.com/watch?v=wU8KTnKVCG0
Jun 6, 2014 - Uploaded by Brian Flugga
I just put a new fuse holder in it with a 1.5 amp slow blow fuse. ...Black & Decker ASI300 Air Station 12-Volt or 120-Volt Inflator
Aug 19, 2015 | Cars & Trucks
IZE FUSES GO INTO A BALLY STRIKES AND SPARES PINBALL MACHINE
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
What fuse controls heater panel
there is many fuses that work different parts of the heater controls, in the battery fuse box (under the hood) fuses (f1-8 30 amp)( f1-9 20 amp )(f1-15 10 amp)(f1-64 40amp) and in the central junction box (inside the car) fuses (f2-36 7.5 amp) and fuse (f2-45 7.5 amp) all these fuses control functions of the heater control hope this helps you out . please leave feedback
Dec 29, 2010 | 2003 Ford Focus
Black and decker air station will not turn on
  1. Take off the bottom(6 screws philips2_bing.gif)look for a small glass fuse Marked F1 that is soldered in place.
  4. If you dont want to wait to order the fust just solder a wire into the fuse area(you will have no surge protection but it may worth the risk because the frequncy this fuse keeps blowing.
Side Note: It may look like the fuse is O.K. but trust me its blown.
There are 2 compessor bellows keep in mind they don't both run at the same time One is for AC the other for DC.
Dec 06, 2009 | Black & Decker ASI300 Air Station Inflator
Black and decker air station not turning on
There's a small PCboard fuse (F1) inside. Remove the six phillps head screws from the bottom plate to expose the PC board. I'm not sure of the fuse size but I'd buy more than one. This seems to happen frequently with these units.
Hope this helps.
MM
May 29, 2009 | Black & Decker ASI300 Air Station Inflator
Black and decker air station won 't work
My Air Station blew a fuse also. The fuse that came with the inflator may be a bit too small amperage wise so I stepped up to .25 Amps more which is just a very small increase.
It is really ill advise to solder a wire in the place of a fuse. You are just asking for it.
The way I did it is I went to my local Radio Shack and got a small fuse holder with red leads and 1.5 Amp fuses. I soldered the fuse holder in place with the new fuse. And now I don't have to deal with any more solder. Just twist the fuse holder, take out the burnt out fuse and replace it with a new one. And wahlah. I'm back in business again.
Apr 04, 2009 | Black & Decker ASI300 Air Station Inflator
1999 Cherokee Jeep sound system
the power amp feeds off fuse 26 in the fuse block under the hood...its a 20 amp fuse...cant find a pic that shows the exact position
Nov 01, 2008 | 1999 Jeep Cherokee
How do I reset the radio alarm preset on Timex (T307S) Clock Radio
if the radio alarm is still showing the nonexistent 98.5, you would need to reset the radio alarm. Press and hold button 1 (top left hand side) until the display starts blinking. Then press the preset button for 98.1. It should then display 98.1 on your radio alarm. good luck this is the most difficult set of instructions I've seen yet
Sep 11, 2007 | Timex (T307S) Clock Radio
Black & Decker ASI300 Air Station Inflator Logo
1,552 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
