No sound and ?beside video but ihave pcie video
    Brigadier General:
  • 10,406 Answers
Sound-cards and video-cards require software, called "device-drivers", to make them function correctly.
Without more information from you about your specific sound-card and video-card (manufacturer? model-number?) the only thing that I can suggest is to access http://WindowsUpdate.Microsoft.com and scan for "custom" updates, and click the "hardware" button, to see if Windows Update has device-drivers for your hardware.
Posted on Dec 13, 2009
How to add a card
open the case up then pull a slot out of the case then put it in put screw in card slot then power up then put in drivers for card
Aug 13, 2014 | Computers & Internet
I have the Board ASUS P5VDC-MX. And I wonder that there is no pci-e slot, but in the information there is written:"this board is pci-e (16x) ready".... is it right ? Can i use a pci-e (16x) video...
No, you can't use a PCIe x16 card in any of the slots on the P5VDC-MX board. A PCIe x16 card can't fit into the PCIe x1 slot. Attempting to force a PCIe x16 card into the PCIe X1 slot will break the card or bend the pins. A PCIe x1 card will work in a PCIe x4, x8 or x16 slot, though. Similarly, the AGP and PCI slots are not compatible with the PCIe x16 card design.
I wish that I had better news for you.
Aug 19, 2017 | ASUS P5VDC-MX (P5VDCMXGREEN) Motherboard
How can i tell the difference between pci slots and pcie slots
The Peripheral Component Interconnect or more commonly known as PCI is a standard for connecting a lot of devices inside your computer to extend its capabilities. Devices like sound cards, modems, NIC, TV Tuners, and some video cards have at some point or another have used the PCI port.
PCI express ( PCI-E ) is a much improved version in terms of speed. PCIe uses a serial interface instead of the old parallel interface used by PCI. It also utilizes individual buses for each of the devices connected to it instead of a shared one like what PCI uses. The difference in speed is quite huge when comparing the standard PCI slot which runs at 133MB/s to a 16 slot PCIe that can send or receive up to 16GB/s.
The most common use for PCIe nowadays is with graphics cards which benefits hugely from the huge bandwidth provided by the interface.
1. PCIe is much faster compared to PCI.
2. PCIe uses a serial interface while PCI uses a parallel interface.
3. PCIe speed is classified into lanes, each capable of delivering up to 1GB/s data transfer.
4. PCI slots are standardized while PCIe slots vary depending on the number of lanes the slot is intended for.
5. Despite PCIe superiority, most manufacturers still use the PCI standard for their devices.
Unlike PCI slots which are the same size for all devices, PCIe slots can differ depending on which form factor it accepts. The longest would be the 16 lane slot and understandably, the shortest is for the x1 devices.
I hope this much information is enough for you to understand the difference between both of them. If you need any more help let me know.. !
May 13, 2010 | Dell Dimension 3000 PC Desktop
Ihave sound on my wharfdale tv but no pictore
Check you video cable if it is well connected if it is then interchange the cables using the one for the audio for the video and other one for the video to connect the audio . If there is no sound then the video cable is bad and need changing but if it produces sound then you will need to visit a local repair man
Apr 11, 2010 | Wharfedale DVD-M3 DVD Player
How do I tranfer video from my camcorder to my computer?
Hello there...
There is another way to transfer video from you camcorder if you camcorder support USB streaming. I usually use this method with my Sony Camcorder because more simple and don't need additional hardware.
Steps:
1) Install you camcorder driver to your PC/laptop.
2) Connect your camcorder to PC/laptop.
3) Open Windows Movie Maker.
4) Create a new project and select source input device to your camcorder.
5) Start record on your Windows Movie Maker application and press play on your camcorder.
6) Wait until camcorder finish playing and press stop in your WMM.
7) Save the file as WMV (later you can convert to another format using any video converter or even burn to CD)
PS: you can even edit the movie frame or add some opening text or end credit.
Hope this helps.... :D
Mar 27, 2010 | Video Cameras
Dell Optiplex GX620 not recognizing PCIe video cards
One of two things could be doing this:
1: Bad Video Cards
2: Bad PCIe slot(s)
If avaliable, I would test the video cards on a PC with a PCIe slot to verirfy if the cards are good/bad. If they work, your PCIe slot is bad and need to have the motherboard replace to correct.
Good Luck
C2Solutions
Aug 27, 2009 | Dell OptiPlex GX260 PC Desktop
I need help choosing a video card - part 2
PCI is the older, slower format, PCIe is newer and faster, but your system MUST support PCIe or it won't work.
So easy option is to find if your system supports PCIe and then get whichever is suitable.
May 13, 2009 | Intel D101GGC Motherboard
Ny foxconn mb doesnot connect with agp video card
If your model number posted is correct, the reason your motherboard won't connect to an agp video card is because it doesn't support agp. The Foxconn 915P7AC-8KS uses PCIe for the video bus, so you would need to use a PCIe video card. (PCIe means PCI express, specifically PCIeX16 is the form factor that you would need.) Hope that this helps.
Jan 06, 2009 | Foxconn 915P7AC-8KS Motherboard
Where does a garphic card fit
Your intel D102GGC2 motherboard has only PCIE slot (black connector- not the memory slot). Its located beside the buttton cell of the mother board. If your graphics card is PCIE, it would directly fit on the black connector.
Jan 03, 2009 | Intel D102GGC2 Motherboard
Computers & Internet Logo
David Payne
David Payne
