Question about SanDisk 2GB microSD Memory Card
Why is my 2gb sandisk memory card not working, whenevr i insert the card it doesn't show with a message saying 'memory card inserted' ?
  • abdi4lyf Dec 12, 2009
    no change, it is stll the same
    yes, it has worked before, i havent used for lke 3 weeks
  • 430 Answers
Try cleaning contacts on card with alcohol and retry
Posted on Dec 12, 2009
  • Tommy Thomas
    Tommy Thomas Dec 12, 2009
    has it ever worked before?
  • Tommy Thomas
    hmmmmmmmmmmmm try going in control panel and try add new hard ware option..let pc scan for it...it should reconize it if not i last suggest..using air... blow out scan disk insert area....lightly spray ....dont over spray ...i hope this helps gl
SOURCE:
I inserted my 2gb Sandisk chip into my blackberry curve, it says nedua card can not be accessed due to fatal errors. How do i fix that?
format the memory card with a software phone..
Insert the sd card into software phone(eg nokia 6120c, 5800, 5233 etc)
Select settings > data mgr > memory > options > format memory card..
Sep 23, 2011 | SanDisk 2GB microSD Memory Card
How do i shut off write protection
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 16, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card is locked how to unlock
Aug 12, 2011 | SanDisk 2GB microSD Memory Card
The SD m2 2gb Micro does not work on my phone
the card shows sign of a rom ic being lost its firmware
Sep 05, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Card not working anymore
check that you didn't lock the card by mistake- there is a small "sliding door"- make sure it is covering the hole.
Jul 21, 2009 | SanDisk 2GB microSD Memory Card
SanDisk 2GB microSD Memory Card Logo
166 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
