Question about Kohler Home
Where is the model number located on a kohler whirlpool tub?
On a toilet its under the rim
Posted on Dec 12, 2009
K-1357 kohler whirlpool tub there is leaking only when the tub is filled and drained. when taking showers there are no leaks 3yrs old
Overflow? Seal around drain may be good enough for shower, but leaks with a little more pressure from the filled tub. Filled tub may flex the tub and drain components. What about the overflow. I bet some water is going over, but it isn't used for showers. Double check. Paper towels tied in stratigic locations always help me find a leak. Leak makes the towel soak up water nearby. It's most wet at the point of leak.
Mar 08, 2015 | Kohler Home
Where the filter is located
There are no filters on jetted bathtubs. There is a screen with dozens of holes located in the footwell of the tub. that is the suction cover. the water flows through that screen into the front of the pump and then out through each of the water jets.
US Parts Center
Aug 21, 2013 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
I bought a house with aqua glass whirlpool tub (14 yrs old). Motor won't come on and I can't find reset button or serial number. Where are these items?
will have to remove access panel or make one the motor /pump assembly is mounted to the tub test for power to the switch and pump the numbers u are looking for are their by pump
May 03, 2010 | Kohler 1209-LA-0 Hourglass Whirlpool with...
Kohler bath whirlpool turns off after 1 second
When you say turns off, is it tripping the safety circuit?
Dec 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Kohler Whirlpool tub motor wont turn on
Kohler Whirlpool tub turns on and shuts right off. Reset gfi and motor turns on and shuts right off. Help
Mar 15, 2009 | Kitchen Appliances - Others
Kohler whirlpool will not shut off and sounds like about to blow
Sounds as if you may need a new switch to turn the tub on/off. You can find one on our site www.uspartscenter.com
Feb 28, 2009 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
Kohler whirlpool 5' tub
Here is the link to the Kohler 1209-LA jets exploded view:
Kohler 1209-LA
Hope this helps!
Nov 15, 2008 | Kohler 1209-LA-0 Hourglass Whirlpool with...
How to identify make and model of old whirlpool tub?
This is a problem common to all whirlpool/air jet style tubs. The pumps become air locked due to the water evaporating from lack of use. All tubs need, and have, SOME means of priming the pump, this is most likely what the problem was, originally, for you. This time in particular you found it to be electrical in nature but for future reference, for you and all who have these style of tubs, I am putting this out there. Some where on the tub, usually along the top edge of the tub is a vent knob that controls the amount of air that the pump is allowed to mix with the water for the jets, usually by closing this valve all the way (tub needs to be full of water of course) and running the pump for a minute or 2, you should be able to get the pump pumping water again, if not you may need to do something else with your particular set-up to get it purged of air, the pumps in jacuzzi tubs are designed to pump water, not air, so if the motor is running but you get no jet action, your most likely air locked and need to prime pump/purge air.
Sep 22, 2008 | Home
Home Logo
119 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
