Question about GE Washing Machines
GE washer Model S3600DOWN will not turn off water. overflows WHY?
    Scholar:
  • 49 Answers
Suspect water level control they call it a pressure switch
there is a quarter inch line that runs from tub to pressure switch that line can sometimes plug requiring line be removed from pressure switch and cleared
http://www.repairclinic.com/Washing-Machine-Top-Load-GE-Style-Appliance-Diagram
this web page shows a breakdown of commom top load ge washing machine level control is located in top panel
before opening top panel unplug washer from wall
if clearing line does not work level control will probably need to be replaced suggest take picture or draw out
where three wires are hooked before removing part or
change 1 wire at a time to avoid mixing up wiring
Posted on Dec 12, 2009
Washer overflowed after moving Load Capacity Switch from Super to reset and then to Large load?
On this model of washer you have 4 separate components that could cause overflowing. The water valve, pressure switch, pressure switch hose & the air dome. If you have to turn the water off to prevent overflowing, I would recommend replacing the water valve. If you can turn the timer off & the water stops overflowing, I would recommend checking the pressure switch, hose & air dome.
Jan 16, 2011 | GE Washing Machines
Myn washer always overflowes as it filling it wont
This is usually the pressure switch. Also you could check the water inlet valve if water is still flowing in the machine after it stops. There are free videos on testing these components at www.appliancehelponline.com/servicemanual.html
You can also punch in your model # for diagrams
Mar 18, 2010 | GE Washing Machines
Washer is filling too much and water is coming out overflow
you need to clean the pressure swith hose on the lft side of tub small rubber hose stop use in liqid soap
Jan 30, 2010 | GE Washing Machines
GE washer won't spin
you need to post your model number
Mar 31, 2009 | GE WDSR2080D Top Load Washer
GE WJRR4170 washer comes out of overflow tube on super load. It does not on Large load size. I have the front off and can see a large difference in water level from large to super size. Is this adjustable?
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
Mar 15, 2009 | GE WVSR1060A Top Load Washer
GE Washer WHDRR418E1WW overflows the tube. Yikes.
A washer that over flows in the fill cycle sounds like a faulty pressure switch. Part # WH12X10069 and 10 on this diagram. If it overfills the tub when the washer is off it's a faulty water valve. Best of luck Ryan
Feb 19, 2009 | GE WBSR3140DW Top Load Washer
GE WBSR WASHER WATER OVERFLOWS
He probably disconnected the water level sensor when replacing the belt or the timer is dead.
Check for any unconnected sensor or check if the main program button is turning propely..
cheers
Dec 20, 2008 | GE WBSR3140DW Top Load Washer
My GE washer wont stop filling with water or go to the wash cycle. my GE top load washer water will not stop and leaks out, overflows. model #GCXRPO9ODAWW.
You have a problem with the water level switch.  It is located in the base of the machine below the tub.  Replace it and you'll be fine.
Nov 20, 2008 | Washing Machines
Water leaks out from underneth
We have a WDSR2080D GE washer and had the same exact problem. We replaced the water pressure switch ($30) to see if that was the cause. A malfunction in this switch would cause the leaking from the bottom because there would be no way for the washer to "know" that the tub was filled to the appropriate level--causing the tub to overflow. Then we found out that the water pressure switch was not the cause and found that the water pump switch was the problem. A malfunction with this switch would cause water to continue to fill the tub without stopping--which would cause an overflow. Think of it as turning on a faucet without the ability to turn it off. Happily, we are now with a working and non-flooding washer at only a minimal expense. Note that the schematics for your washer are not in the manual. They are inside the control panel, which means you have to take the front of the washer off as well as the control panel in order to see what's really going on. My guess is that GE would rather consumers not try to fix their own appliances so they put instructions and helpful hints INSIDE the appliance.
Jul 23, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
208 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
