I have a Kenmore 110 model# 4563291. It has stopped agitating and spinning.
  • harley2936 Dec 12, 2009
    Thank you so much...there is a humming noise after it intially fills with water and than does nothing.  I am going to find a coupling and replace via your instructions video you sent.  Would there be anything else wrong with it if I replace that and it still doesn't agitate.  Just wondering, because while I have the washer taken apart....I would replace any other possible problems while in there.  Thanks
    Awesome....i will try this as soon as I find the part.
  • Washing Mach... Master
  • 3,361 Answers
If it fills with water and then all you hear is a slight humming sound your direct drive coupling between the motor and transmission is bad. This video will show access and repair of the coupling.
http://www.youtube.com/watch?v=WLPGs2UMUJc&eurl=http%3A%2F%2Fappliancejunk.com%2Fforums%2Findex.php%3Ftopic%3D67.0&feature=player_embedded#t=15
If it fills and stops with no sound at all,the lid switch is bad. To check lid switch,set the timer for final spin and turn it on. If you hear noise the lid switch is OK. If no noise,replace the lid switch.
This video will show access to the lid switch.
http://appliancejunk.com/forums/index.php?topic=5191.0
Posted on Dec 12, 2009
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Machine agitates but doesnt spin or pump out water
you will need lid switch 285671.. whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 24032\24036 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
KENMORE WASHING MACHINE MODEL#110. 254872300 WONT SPIN
if your sure it will agitate?[because the pump is on the other side of the motor and will drain,but if coupler broken ,wont agitate or spin although it makes noise like its working.so if will truely agitate drive coupler fine and its going to be the clutch or that area unless somthing[clothing] is between the two tubs creating anough resistance to stop the tub from taking off.clutch pads will just slip on drive plate.hope that helps>God bless ,tom
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Unit filled, but now will not operate
so it dosent make any noise?your lid switch will stop it from draining and spinning but it will agaite on most kenmore waskers.if i came to repair that would be my starting point
Jan 01, 2009 | Kenmore 24032\24036 Top Load Washer
No agitator action
I need to get the model of the washer. (e.g. 123.123456789). This will greatly help to identify the problem and a fix for the washer. Thanks
Jul 07, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
