Question about HP Color LaserJet 2600n Printer
Printer I have a hp Laserjet 2550 PCL 6 printer. It has been working fine until now. I have shut it off several times to reset it, but that does not work. I have 2 green lights on and a red one. I try and print something and it says that the printer is out of paper even through there is paper in it.
  • 167 Answers
Its not the paper problem! Its the drum unit!!! try to take it out and put it back!!!
Posted on Jan 24, 2008
Following a printing job of more than two or three pages, both orange lights and both green lights come on. The printer then is not functional. There is no paper jam. If I turn it off, then back on, it...
I had this problem at work. We went from a PCL 6 driver to a Universal PCL 5 driver and it worked fine printing multiple pages. And has ever since. I would check your driver first and see if it can be updated. If so, update it and try again. If not or updating doesn't work, try a different driver, especially if you are using a PCL 6 on a 32-bit or an XP machine. Best of luck to you.
Aug 04, 2011 | HP LaserJet 4L Printer
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
May 27, 2010 | HP Laserjet Cp2025n Printer
HP LaserJet 1200 Series PCL 6 PAPER JAM HOW TO RESET PRINTER
IF THE PAPER JAM IS REMOVED THE PRINTER WILL RESET BY ITSELF.CHECK TO SEE IF THE PAPER SENSOR ARM IS NOT STUCK
Oct 02, 2009 | HP LaserJet 1220 Printer
LaserJet 4000 driver problem
I had the same issue. I completely uninstalled the pcl 6 drivers twice and reinstalled and the printer mysteriously worked just fine.
Aug 10, 2009 | HP LaserJet 4000 Printer
HP Colorlaser CP2025dn PCL XL error Subsystem: KERNEL Error: IllegalOperatorSequence Operator: BeginPage Position: 14 Printer worked fine until I bought a new computer. Installed fine. ...
This seems like a driver issue to me. Are you using the Universal, PCL5 or 6, or PS driver?
If using PCL and are getting this error, try the Universal HP driver from the website. Likewise, if you are using the universal, try the PCL6 device specific driver.
If this fails, let me know and I can assist further
Jun 19, 2009 | HP LaserJet P2015 Printer
Pcl xl error , subsystem:kernel, Error: Illegal tag
Change paper to plain instead of UNSPECIFIED in the printing properties. The printer hates the UNSPECIFIED setting.
Jul 26, 2008 | HP LaserJet 1320n Printer
Laserjet 1022n and Universal Print Driver
i solved this problem in my case with an compatilble standard driver from windows. An PCL Laserjet 5 / Laserjet 6 Driver.
And no problems occour.
On the clients and the server all iss fine.
Apr 07, 2008 | HP LaserJet 1022n Printer
HP Color LaserJet 2600n with Windows Cluster
Is the driver the same as a 2550? Maybe you should download a 2600N driver from HP.
Mar 18, 2008 | HP Color LaserJet 2600n Printer
Printer error
Hi there guys reinstall the driver using PCL 5e as the program you are using may not understand the PCL 6 newer driver. Try this
Hope it helps
Thanks J
Nov 14, 2007 | HP Color LaserJet 3500 Printer
HP Color LaserJet 2600n Printer Logo
96 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
