Question about Compaq fs740 17" CRT Monitor
The video camera
I can't figure out how to connect the camera that the compaq fs740 came with to the internet. if you know a solution that'd be great. Thanks
  • Anonymous May 30, 2008
    dose it have built in webcam
  • 85 Answers
Is it built into the monitor? If so, then there should be a USB port on the back/bottom of it or something of the sort. Are you telling me that you don't know how to connect it physically to the internet, or that you don't know how to connect it software-wise?
Posted on Mar 24, 2008
Compaq monitor FS740 is turned off after some time
Step 1:
Check your screen saver setting.
Step 2:
check your monitor setting to always in active mode.
Jan 10, 2013 | Compaq FS740 Color Monitor
Inherited Compaq FS740 but after hooking up monitor will show green for a short time and then color is yellow? Is it dead? Has set up for a while
Check the pins on the cables. Single color presentation but clear picture indicates the pin for a particular color is borken on teh cable. Remember Red Green and Blue are mixed to make other colors. If you have predominantly one color then its due to cable not haveing all pins inserted properly or damaged.
Jun 28, 2010 | Compaq fs740 17" CRT Monitor
Compaq FS740
try pressing escape. or press f8 when your computer starts up and then press factory restore
Jun 22, 2008 | Compaq fs740 17" CRT Monitor
Monitor screen problem
Check your cables. Make sure they are secure.
Apr 07, 2008 | Compaq fs740 17" CRT Monitor
It is one coulour missing and it can b mostly due to CRT socket loose or some dry solder in CRT {RGB) path..
Chck out...
This is a technical freak from INDIA!
Monitor is tilted forward and wont tip back
it will tilt back, just make sure the stand is in the forward most position and not turned and hold the screen at top and push while at the same time pull at the bottom, it will be quite stiff.
Sep 23, 2007 | Compaq fs740 17" CRT Monitor
Compaq fs740 text too faint and fuzzy to read well
Firstly you need to switch to the monitor's optimal resolution of 1024x768 @ 85Hz and before anyone posts anything about resolution 1024x768 @ 85Hz is the optimum not the maximum. To change to this resolution: Assuming you are using Windows XP click with the right mouse button an an empty part of the desktop and select Properties (or click Start, then click Control Panel then click Display), on the Settings tab, under Screen resolution, drag the slider bar until it says 1024x768 and then click Apply. Also in Display settings you'll find an advanced button, in the advanced panel you'll see the option to adjust the refresh rate, try adjusting this to 85Hz. Now press the Menu Button on the front of the monitor and press + of - until you see an option called "Degauss" and press the select button on the front of the monitor, your screen will do a disturbing jump and flicker accompanied by a metallic thud, this is normal. If this doesn't help message back.
Aug 26, 2007 | Compaq fs740 17" CRT Monitor
Compaq fs740
u need to go into your control panel then display settings to adjust rersolution
Aug 17, 2007 | Compaq fs740 17" CRT Monitor
Compaq monitor
OK your monitor is failing in the Horizontal circuitry.... OR the PSU is failing to supply the correct Voltages. Either way it is probably going to fail completely soon. With monitors so cheap now, here in NZ they are about NZ$20.00 - $50.00, repair isn't adviseable to do so, it would make more sense to put the Repair monies into a NEW screen... maybe time for an LCD?
Jul 22, 2007 | Compaq fs740 17" CRT Monitor
Concave screen problem also
OK All these Compaq's have a Power Supply problem, or a Horizontal Voltage problem.. meaning they are on the way out. The SMPSU's in these units often fail along with the Horizontal Drive Circuitry. I think it is time for a new one? Repair of such a unint would barely be "Ecconomical" IMHO.
Jun 08, 2006 | Compaq fs740 17" CRT Monitor
Compaq fs740 17" CRT Monitor Logo
71 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
