Question about Water Heaters
The timer on our hot water Grundfos recirculation pump (built in) does not seem to be working any longer. Is there a place that I can get a replacement and easily replace just the timer (the pump seems to work fine if the timer is simply switched to "ON" and always run)?
  • dasegal89 Dec 12, 2009
    Great help. Thanks.
  • 10,865 Answers
Hello. Yes, these timers are easily replaced. You do not need to break into your water pipe in order to replace the timer. New timers are available at any plumbing supply house, or on line at a site such as http://www.google.com/products/catalog?q=grundfos+timer&hl=en&sourceid=gd&rls=DLUS,DLUS:2009-43,DLUS:en&um=1&ie=UTF-8&cid=1775836018895734731&ei=VfQjS7PMBpOZlAfI-LD2CQ&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CBIQ8wIwAg#ps-sellers. It is always best to replace the current timer with a new one that is identical if you can find it. That said, be sure that your timer is set to the correct time, something that you need to do every time their is a power outage. A new timer should run you about 60 dollars. Finally, here is a little video which will give you even more insights into your recirculation system:
http://www.youtube.com/watch?v=URJ_-u6uDoI
Regards, Joe
ps. please rate my answer. Thank you.
Posted on Dec 12, 2009
I have an instant hotwater system with the futher most bathroom about 45' away. I am looking at adding a recirculating pump on a timer at the furthermost bathroom to get hotwater quickly in the...
Maybe I am not understanding your problem exactly, but if you have the instant hotwater system installed it should be measuring the temperature of the water in the hot water line and if it drops below the set level it should open the hot water side until the temperature is reached. If it was installed correctly it puts the hot water back into the cold water line so it isn't wasted.
Sep 18, 2011 | Grundfos RCP-96 Recirculation Pump for...
Laing model 330 Pump not working-delay in hot water delivery.In the past,a vibration occurred when cold water running above the pump.Can this be repaired.Power operating to pump. Thanks, mel ross
Question not 100% clear.
1) The pump is not working? Does the pump make a noise? if pump is not working full-time, it can cause delay in arrival.
If pump motor is suspect, and outlet has power, then check override switch located on timer. Set override to Timer, move some of the trippers outward, then manually rotate timer dial until pump turns ON.
http://waterheatertimer.org/images/IMG_9325-grundfos-timer-800.jpg
If no noise is detected, or noise stops and starts, or seems strained, or if pump is hot, then pump motor may have burned out.
2) If pump is working, and makes noise like a humming sound, and pump motor is not hot, but hot water is not circulating, then unplug pump so it will not overheat and burn up.
Disassemble the pump and cross-over piece. Clean piping with white vinegar or CLR. Do not soak in CLR or it will damage seals. Rinse parts thoroughly. Reassemble and see if problem is resolved.
If pump is vibrating, then suspects include sediment and/or air inside line, and this can be resolved by cleaning as described. Also install air vent to increase life of pump.
3) Other causes for hot water delay at faucet are crossover.
Crossover can be caused by bad single-handled faucet cartridge, and/or by clogged-or-failed check valve on cross-over piece on grundfos.
This type of problem lets cold water enter hot line, and causes delay in arrival of hot water. Clean-or-replace the grundfos cross-over piece, and replace bad faucet cartridge.
Open following link for testing instructions:
http://waterheatertimer.org/Crossover.html
Resources:
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/pdf/Troubleshoot-recirculation.pdf
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 17, 2011 | Laing Thermotech Autocirc Undersink...
Resources:
Grundfos recirculating system. Never has produced semi instant hot water at sink it is installed on. Could the original comfort valve be defective
The circulation system should draw hot water directly from the water heater as shown on illustrations on link above.
The Grundfos pump works on a thermostat, and some work on a timer.
Can you hear the pump working?
There should be a humming sound.
Check the timer -or- thermostat setting.
It is possible the lines are clogged with sediment if you have hard water.
If I was going to fix the problem:
1) check thermostat or timer
2) listen for pump sound
3) check electricity going to unit
4) take apart the pipes and inspect for clogging
If there is a clog, I would flush the line or soak the part in CLR (calcium lime rust remover)
The circulation pumps are sealed and there is no way to take apart the motor, timer, or thermostat for repairs.
add a comment if you need more assistance.
Nov 05, 2010 | Grundfos Comfort Series Replacement Valve
Grundfos submersible well pump with Grundfos CU301 control. Control box shows no contact to pump. What is the problem or problems?
Grundfos is a p. o. s. I have a new system cu 301 and I have had to get it repaired twice by Fogle Pump and Supply. These guys are real rip of artists in Washington State and should be reported to the BBB. Dont Use Fogle if you need a well
Sep 15, 2010 | Grundfos RCP-96 Recirculation Pump for...
Grundfos recirculating retro fit hot water out of the cold side
they have it installed wrong it is pulling from the wrong side, it is supposed to pull ot water up to the fixture but then if it stays hot on the cold side they are backwards
May 27, 2009 | Grundfos RCP-96 Recirculation Pump for...
Does grundfos rcp96 pump work with bosch 2400 eo tankless heater?
What is your reason to have a recirc line on your water heater does the heater sit to far away from a certain fixture? If you put a pump on your tankless waterheater then your heater will continually fire till the call for hot water is stopped. Yes you normally do need a seperate line installed for a recirc line usually from the water heater to the farthest fixture away. If your problem is taking to long to get hot water then I suggest installing a second heater closer to problem area.
Apr 16, 2009 | Grundfos RCP-96 Recirculation Pump for...
Water Heaters Logo
18 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
