Question about Ionic Pro CA500 Air Purifier
My Ionic Breeze air purifier makes an intermittent static noise when operating. What could be the cause and how can I fix it.
    President:
  • 1,985 Answers
You need to turn it off and remove plates,put in kitchen sink and spray with windex and dry with paper towels, now clean the bottom of the three plates too.
before you reinstall the plates look down inside you will see three thin lines of metal,make sure there is no lint or dust on them,reinstall and let set for five min. to allow any windex that might still be wet then turn on low for a couple of min.then go to medium
Posted on Dec 28, 2009
SOURCE:
My ionic pro ca500 has the blue light on but also is making a intermittent sizzling sound, I have wiped the blades, the clean light is not on.
What does the blue light mean? I had 4 Ionic breeze air cleaners, ionizer wires are broken. I was thinking about buying the Ionic Pro cleaners, but have no input about how well they work.
Dec 02, 2013 | Ionic Pro CA500 Air Purifier
My Ionic Pro keeps making a static-y noise when turned on. What is causing it and how can I fix it?
Hi jackieelling,
I work for the Ionic Pro company. Make sure you are also cleaning the ionizing wire. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Feb 05, 2011 | Ionic Pro TURBO Air Purifier
One of the the two plates/contacts at the bottom of the filter is broken, what can I do to fix it?
Hi.
If you need parts or repair for new models contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read the below, in that case do not get the parts.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Note:On this particular problem: It is caused by arching, that was a factory defect. It is repaired replacing the plate. Since this is an old model, I suggest not repairing the unit.
Regards.
Ginko.
Sep 20, 2010 | Sharper Image Ionic Breeze 3.0 Air...
My ionic breeze quadra air purifier keeps turning on and off. I have cleaned the fins, what else can i do?
Hi.
The filter will probably need replacement. Ionic breeze purifier are not being manufactured anymore because of heath concerns. Parts are also not distributed anymore.
Regards.
Ginko.
Sep 08, 2010 | Sharper Image Professional Plus Ionic...
Even after cleaning (3 part) my purifier is still making static noise intermittently
Please call customer service at 800-875-8577 so they can trouble shoot the unit for you. If need be, they can replace it for you.
Mar 19, 2010 | Ionic Pro TURBO Air Purifier
Ionic Breeze GP S1830 just seems bead, no lights
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Sep 11, 2009 | Sharper Image Hybrid GP (SI724) Air...
Ionic air cleaner
take out the insert and clean it real good ... there is a leaver on back of the machine move it up and down about 10 times to clean the strands ...... make sure you clean the 3 steel thin metal strips good let it dry before you put it back in to the machine ..... + i have that same machine - i have 2 cats - it gets dirty quick
pss the poping sound is the machine is telling you it is dirty ... static electric charge
Sep 03, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Describe your Sharper Image Professional Plus? Ionic Breeze® QUADRA? GP Silent Air Purifier Problem: We cleaned it, now it makes a noise. How long is the warranty? Any idea what the noise is? ...
Warranty on these units expired on the 30th of May, 2008 when the company's assets were acquired and liquidated by Hilco Consumer Capital, Gordan Brothers, and Bluestar Alliance. All warranties became void with the bankrupt status.
With regard to the unit that you cleaned, I am assuming that you cleaned it the usual way you always have and it is now making a statical noise or a vibrating kind of noise, correct?
While the unit is off, take out the insert, pick up the unit and turn it upside down. You will hear some beads moving from the elevated end moving towards the bottom. Turn it upside down again and let the beads move to the bottom again. After doing this a few more times turn it upright and put the insert back in. You just cleaned the static lines. Turn the unit back on and see if the noise is still present. If so, try cleaning the insert again and after drying, see if the noise is still present. It is usually some dirt present somewhere that causes the noise to persist. If you have completed everything and the noise still persists you need a new insert which you can get on ebay.
Jun 30, 2009 | Sharper Image Professional Plus Ionic...
The orange tape on the bottom of the ionization bars
There being two strips of orangey tape at the bottom of the rods wipe clean the two thin wires stretching the length of the ionic breeze each time you remove the filter elements to clean the filter. Seems like these wires may be emitting the audible high pitched noise if dirty.
Frank
Jul 12, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Intermittent "static surges"
Ionic Breeze is no longer supported because Sharper Image went into bankruptcy as a result of these products proving to be ineffective.
Here is a Sharper Image article
Here is an EPA article
Jun 17, 2008 | Sharper Image Professional Plus Ionic...
Ionic Pro CA500 Air Purifier Logo
505 people viewed this question
Top Ionic Pro Air Purifiers Experts
senbukan
Level 1 Expert
Kardoc
Tom Chichester
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
