Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Flat panel displays half screen, mirrored on bottom half of screen
Help! Picture displayed on top half of screen then line through the middle of screen with a mirror image of the top. (displayed upside down)
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
Have several problems with either a bad LVDS cable from Main unit to the LCD controll bd. Sometimes the cable is just not connected properly. If you reseat this cable and the problem still exists you most likely have a bad LCD control bd.
Posted on Feb 03, 2008
Pioneer pro-1130hd no image top half of screen which board does this issue point to the x or y drive
X is for all display lines
Y is for individuals.
Go for Y board since half screen is working.
Feb 18, 2016 | Pioneer PRO-1130HD 50 in. Plasma...
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Luxor lux0140001B/01 1 week old picture has top half with a grey see through screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Apr 12, 2014 | Televison & Video
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Lg 50pc5d
If picture only one side or only top or bottom set uses two boards to drive the screen, either one of them is bad or the actual display panel itself--it is the entire screen unit where the picture is displayed.
May 25, 2012 | LG 50PC5D Television
Screen appears broken but it is behind the glass a star like pattern on top right
sounds like a damaged screen or "display panel" which are used in LCD and Plasma sets----damage to it is fatal as the part wholesale costs more than the set did when brand new.
May 17, 2012 | Televison & Video
I have picture at the top and verticle lines at
Your panel needs replaced. Half a picture, top to bottom, provides a quick diagnostic. You panel has a Timing Control (T-Con) board failure. Watch out for part cost, it may be cheaper to replace the TV rather than repair it. I hope this helps.
Mar 16, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Half screen lighter than other half
faulty display panel or faulty display driver
Aug 31, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
580 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
