Question about Dishwashers
Will not drain - Dishwashers
  • 96 Answers
Pump is out or you discharge line is pluged take a shop vac and **** the discharge line out
Posted on Dec 13, 2009
Water will not drain. humming noise
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Humming noise is due to loose connections on drain pump or due to faulty drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Nov 20, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My dishwasher is not draining all the way where is the drain? Maybe it is plugged?
Hi
Oct 25, 2010 | GE Profile PDW8400J Built-in Dishwasher
Drain is plugged, leaking water
Hi
Oct 20, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Water does not drain out completely after cycling
Hi
Oct 20, 2010 | Whirlpool DU943PWK - Multiple Color...
Will not drain completely problem started after a power outage.
Hi
Oct 20, 2010 | Whirlpool Dishwashers
Dishwasher is not draining
Hi
Oct 20, 2010 | Jenn-Air 24 in. JDB2100AWS Built-in...
My dishwasher cleans ,but does not drain the watr fully. Please help. Thanks
Hi
Oct 20, 2010 | Maytag Dishwashers
Not draining and making noise
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump. The noise you are hearing is from the drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Daniel
Aug 20, 2010 | Dishwashers
Won't drain
Hi
Daniel
Aug 07, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher does not drain in normal cycle. on
Thoroughly clean drain screen and drain. Add small amount of drain cleaner to drain, flush after five minutes. Do not add hot water with drain cleaner.
Jul 07, 2009 | Dishwashers
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
