Can't light pilot on rudd model urcf 07e24jkr
    Problem Solver:
  • 10 Answers
If your furnace indeed has a pilot, a thermocouple or gas valve is your culpret. Thermocouple is about ten bucks from The Home Cheapo so it is a good inexpensive start. That is the copper stick that the pilot flame hits. Turn off the gas and electric when changing it. If it still won't light then you will need a qualified HVAC tech to replace your gas valve.
Posted on Dec 13, 2009
Rudd furnace pilot wont stay
You have one of three things here
1. Dirty pilot, needs to be cleaned.
2. Bad thermocouple needs to be changed and pilot assembly cleaned.
3. Bad gas valve pilot solenoid call a repairman
Nov 09, 2014 | Heating & Cooling
Rudd furnace pilot wont stay lit
Have your local gas compreplace your thermocouple.
Nov 09, 2014 | Plumbing
What is the AFUE of my Rudd Achiever 90 Plus with model number UGRA-07EMAES
Per Rudd's website and also as the name implies, the min rating is 90. The 90+ can be as high as 93 but is stated as "plus" to cover the many possible installation scenarios which will impact overall efficiency of the unit.
Sep 11, 2014 | Heating & Cooling
Need to replace a RGDA-100A-AR Rudd
it could be a bad flame sensor. if the control board doesn't sense a flame it will shut down the unit
Dec 15, 2013 | Weather King Heating & Cooling
Goodman gmt070 inductor fan clicks on, pilot glows, nothing
Possible bad igniter...igniter should read somewhere from 50-90 ohms. If not it is going bad. Remove igniter (don't touch carbon silicon rods) see if you see minute cracks or white spots. If ohms testing reads in 90 or above range , replace igniter. ( note some rheem, rudd and weather king igniters normal ohm range can be 130-150 ohms).. You might also want to check the igniters connections and control board module to make sure the the igniter is betting the proper voltage to get the igniter hot enough.. 110 volts or about is the input norm to the igniter.
Nov 21, 2013 | Goodman GMS90703BXA Heater
I have Rudd hot air gas furnace. The ignitor sparks and lights the fire but as soon as the ignitor goes off the fire goes out, flame light doesn't go on. What could be the cause?
Hi, Check the flame sensor next to the pilot. It should be a ceramic rod with a metal tip that rests in the pilot flame. It may be dirty. Clean the tip with steel wool real good and make sure it is in the pilot flame good. This will cause that condition to happen. If this doesn't take care of it, get back to me and we will go from there. Should solve you're problem. Merry Christmas,
Shastalaker7
Dec 25, 2009 | Ruud UBHC Air Conditioner
Fails to ignite,sparks but pilot will not ignite. have had problems with pilot going our for about three months. Thought attic air flow was the problem. closed off air vents in area of heater. problem...
Sometimes the pilot orrifice get plugged up and need to be taken apart and cleanned,,,,,, adjust the pilot flame on the gas valve, or check gas going to the unit to see if the in-line gas valve is opening and closing.
Dec 09, 2009 | Ruud Heating & Cooling
Relighting the pilot for a rudd heating and air
I dont know of any manufactor that makes a stand alone pilot anymore. (pilot you have to lite). The pilot should lite itself when you turn on the heat.
Sep 24, 2008 | Heating & Cooling
Rudd gas pack schematic
Email me and I can send you the schematick
Richard (Rick) Drennan
Global HVAC Distributors
Field Support Representative / Instructor
rdrennan@globalhvac.com
900 Spreckels Ave
Manteca, Ca. 95336
Office (877)448-7263
Cell (209)456-0513
May 06, 2008 | Ruud UAMB Air Conditioner
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
