Question about Kenmore Washing Machines
My kenmore 90 series washing machine will not agitate or spin, but will drain. If it is a belt problem, how do I change the belt?
  • oldguy5 May 11, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Actual Model Numbers are necessary to correctly diagnose the problem.
    Problem Solver:
  • 13 Answers
Its not the belt. check the lid switch, its already cracked open
Posted on Dec 17, 2009
Kenmore washing machine series 90, will not agitate, spin, or drain. Door switch is good. Wigwag solenoids have continuity. Motor start capacitor good. Motor will spin if belt removed.
Unplug the unit. Remove the hoses on the water pump to check if it is clogged. Water will come out so be prepared. Check how you can check for error codes.
Dec 13, 2016 | Kenmore Washing Machines
Machine won't spin, therefore water cannont be emptied. The agitator works. I have a top open Kenmore 90 series machine.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 14, 2011 | Kenmore Washing Machines
Kenmore 90 series washer. As the tub tries to
It sounds like you have a bad timer. If you change the position of the timer and it does not change what is going on the the timer has to be bad. However I am not certain what you mean by the agitator turns all the time. Is it agitating while spinning and draining?
Apr 15, 2010 | Kenmore Washing Machines
Kenmore 90 series heavy duty washing machine will agitate, but will not drain or spin.
check drain solenoid valve.follow drain hose into machine.valve should be lcated in this area.
Oct 16, 2009 | Kenmore Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
146 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
