Question about Mitsubishi WS-65857 65" Rear Projection Television
Need to know which two picos protect the convergence circut
  • Mitsubishi Master
  • 5,138 Answers
If you have convergence Problem replace Both of your STK ICs they are big black ICs will have Part Number on them example STK392-570
Call Mats Electronics for Parts Cost of ICs $10.95 each
1-800-628-1118 ASK them to send you a Catalog Too!
Posted on Dec 20, 2009
I change the convergence IC and still defective
Check PS8001 to PS8006 Pico fuses all 3.15amp on the D board,
also check PS5001 and PS5002 on the G board 5 amp Pico fuse
May 17, 2014 | Sony KP-51WS500 51" Rear Projection...
My mitsubishi 48' wideacreen tv will not turn on.
Sure, two,two is short protection: One of the two pico fuses that protects the convergence circuit is blown----you will need to replace both chips (Need a exact model number to tell which) and the pico fuse that is blown.
SD TECH
Aug 28, 2012 | Televison & Video
I have error code pv1.22 the tv does not turn on any suggestions.
Thats the code for short protect. Usually its the convergence which has blown F9A04 or F9A05 if either pico is blown the convergence IC and picos will need replacement
Nov 26, 2009 | Mitsubishi WS-48613 48" Rear Projection...
Mitsu WS-65909 COMES ON AND TURN OFF IMMEDIATLY, ERROR CODE 2-2
Two blink code on this set means Usually one of the two pico fuses that protect the STK-393-110 CONVERGENCE IC is blown--the fuses will need to be tested and the chip and them replaced--
If you have enough skill I have step by step start to finish instructions for this repair in this set---set detects one of the voltages to the Chip is not there and shuts down instantly. I have photos of the chip, fuses and protect resistors this set uses also.
If you want the instructions for free give me a email and I will send them to you for free--if you are able to do this repair yourself you will save a lot of money--you can buy the chip on Ebay for about 14 dollars plus shipping and the same seller sells the pico fuses..............
If you want to attempt this give me a vote here--If you are not able to do it yourself I have suggestions for you about getting the set fixed--I have done hundreds of these sets!
Just reply to this post here.
Let me know what you want to do, I am here to help people
SD TECH
Sep 19, 2009 | Mitsubishi WS-65809 65" Rear Projection...
43FDX15B No picture, Power light stays on
Just a thought, but check all of the pico fuses for a blown fuse. The pico fuses look like a small yellow resistor. Some Hitachi's are famous for having a blown hi-volt ceramic capacitor and a blown pico fuse.
I think the red led on is a short protect indicator, but I could be mistaken.
Sep 08, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Mitsubish WS-819 Protective Shutdown. 2 blinks, pause, 2 blinks
Over 95% of the time a 2 - 2 blink code on that model is a convergence output problem. You need to replace both of the convergence output IC's and perhaps the pico fuses feeding them voltage. The pico fuses are F9A04 and F9A05. They are on the same board with the convergence outputs.
May 29, 2009 | Mitsubishi WS-55819 55" Rear Projection...
WS-55511 code 22.
Check these two green pico fuses F9A04 and F9A05 to see if they have continuity, if they dont have continuity the Convergence iC and those two picos will need replacement.
Jan 31, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi wt-46809
the vertical deflection IC if defective will cause the protection circut not to let the tv power up ,it has a thermal protection circut as well
here is the vertical deflection IC # la78045
and here is a link for the NTE equivalent part and specifications and pin layout
http://www.nteinc.com/specs/7200to7299/pdf/nte7209.pdf WARNING if you heat up any component to long or with to hot of an iron you can dammage the component and or the thermal protection circut
but I believe you will also have to replace the flyback (high voltage transformer ) with wire giving to much voltage
Oct 11, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Convergence problem on sony kp46wt500
on that models its usually the pico fuse that are in line with the resistors that go, they tend to protect the resistors by blowing first. The picos are 3.5 amp
Sep 05, 2008 | Sony KP-46WT500 46" Rear Projection...
Toshiba television
What is the model number on your set, and can you describe double picture alittle more clearer? Is it actually two pictures or are their double outlines? Let me know.
Jan 10, 2008 | Televison & Video
Mitsubishi WS-65857 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
