Question about Carrier Heating & Cooling
Carrier transicold tm900, remove evap cools below set
Carrier tm900, remove evap cools below set point,have voltage to heaters,heaters work when i pull down drain pan to inspect.When i install drain pan then restart.Remote evap cools heaters dont seem to do anything.
  • 8,220 Answers
Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 15, 2009
  • Dan Webster
    Dan Webster Dec 16, 2009
    When you restart the heaters ain't gonna do anything unless you are in a subzero climate and need to keep the contents above the freezing zone. It is all automatic. Keep your setpoints at the temp you want the food. Keep the fuel tanks full.
How do I turn heater off. Its 80 degrees out. And will I be able to turn back on when needed?
lower thermostat set point. and you can put it any temp you wish. heater below set point runs heater ave set point is off
May 04, 2018 | Heating & Cooling
CARRIER TRANSICOLD A/C SYSTEM
I can find no A27 fault code for this unit, what is it doing? You can call carrier and ask for the definition, I think they will give it to you, just have the specific model number in hand when you contact them.
Aug 18, 2016 | Carrier Transicold Division Heat/cool...
When the heater is on, should the fan outside on top of the unit also be working along with the blower from the heater ? When the heater is off, cold air is comming from the vent's, can I cover the
No. This is strictly a gas package unit, not a heat pump. the condenser fan motor should NOT run when their is a call for heat from the thermostat. The condenser fan only runs with the compressor on a call for cooling. Hopefully the compressor is not running @ the same time, but if it is, it would make sense that the contactor for the compressor & condenser fan motor is stuck closed OR the low voltage cooling wires are shorted straight to a 24Volt control wire.
Jan 15, 2015 | Carrier Heating & Cooling
Heater blowing cool air
Is it set on summer switch which is the fan running all the time blowing cold air
Feb 15, 2012 | Heating & Cooling
I need an operation manual for a carrier transicold supra 644
You can order a manual at the following link; http://steprightupmanuals.com/refrigerator-service-manuals/carrier-truck-and-trailer-refrigeration-service-manuals
Just select the Supra 644 through 844 series and I believe it is $6.99 to order from this site.
Oct 29, 2011 | Heating & Cooling
2001 Audi A4 heater blows cool air even when set on Hi. When I park water drips from AC condenser like I was using air conditioning
The EVAP core (the part that cools the air) is similar to a dehumidifier. As the outside air passes through the EVAP core it removes the moisture from the air. The moisture collects on the EVAP core and eventually drains out of the EVAP drain which is usually under the passenger side of the car. This is normal any time the a/c is on.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 06, 2010 | Audi A4 Cars & Trucks
GE side by side GSS20IEP Refrigerator freezer freezing
this is a problem that is no stranger to most GE side by sides; GE has used a glass type defrost heater in the freezer which often fails. If you manually defrost your appliance (unplug and leave doors open for 24 hrs) then plug back in, it will appear to work normally for a few days and gradually build up frost on the evap panel (back panel in the freezer) and eventually the refrigerator side will seem to loose cooling due to frosted damper, or lack of cold air transfer over the evap coil. The fix for this is to replace the defrost heaters (s). While not as common, defrost thermostats can open causing the unit to skip defrost, and even less likely is the defrost control (either mechanical timer or adaptive defrost). First, defrost your appliance, then remove the evap panel and ohm out the heater(s), if open, replace. If they check ok, check your defrost thermostat (small disc like object attached by a clip on the evap. coil itself) for signs of popping open or open ohm readings at normally closed temperatures. Its a good idea to change this anyway when replacing defrost heaters as the two work hand in hand. Last, check the defrost timer by manually advancing the screw advance clockwise until you hear the first click, then check voltage to the defrost heater and thermostat, if no voltage present replace timer. If your appliance is equipped with a adaptive defrost board, refer to the schematic for proper diagnostics.
Jun 11, 2009 | GE GSS20IEP Side by Side Refrigerator
Carrier split 42G250HF-1(indoor unit
I'm not sure exactly what unit you have and what controls you have installed on the unit. But....there usually is a flash code schematic on the unit. Usually on the inside of the blower compartment cover. This should tell you what is wrong with the unit. It could have a low voltage short somewhere and is loosing the call for cool. So the answer can be a possible yes to your question but without knowing the flash code, it's hard to tell from my point of view. You might end up calling a service professional out to check it.
Mar 30, 2009 | Carrier 38CKC042 Air Conditioner
Carrier home ac system
sounds like your contactor is stuck closed.This is the part that high voltage connects to and lets power through to the compressor and condenser fan motor when you get a call for cooling.If you go to pull it out,kill the power outside AND at the furnace.
Aug 12, 2008 | Carrier Heating & Cooling
Not cooling
Replace heater and defrost timer
Aug 09, 2007 | GE Profile PSW26P Stainless Steel Side by...
Heating & Cooling Logo
62 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
