Question about Sony Ericsson K750i Cellular Phone
Central toggle button
It is very annoying not to be able to toggle down left or right without the right 'rouch' cna this be repaired?
    Problem Solver:
  • 5 Answers
I dont think u'll be able to do it sorry. the best thing is to open it up and give it a good clean the helps 9 out of 10 times
Posted on Jan 27, 2008
How can I factory reset a nextbook model NXW101QC232
To enter the Recovery mode (and reach the repair or reset options), with the tablet shut-down, press and hold the power and Vol - buttons. Both of these buttons are on the back near the top right. The power button is the right-most button. The volume - is on the left of the volume toggle and the toggle is adjacent to the power button. This is on page 14 of the manual. You can see the manual at ManualsLib here: https://www.manualslib.com/manual/1155142/Nextbook-Nxw101qc232.html?page=14#manual .
I hope this helps.
Mar 08, 2017 | Computers & Internet
Tip
Broken Screen Delete Messages Nokia 3109 3109c 2323 2323c
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Delete Inbox Messages Blind Nokia Broken Screen
Press Central Navigation Button to get Menu
Press left once
Press up once - Message Menu
Press Central Nav Button
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Press Button above call end several times to exit from the menu
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken Screen
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
on Aug 06, 2010 | Cell Phones
Tip
Saving contacts to SIM with Broken Screen Nokia 3109 3109c 2323 2323/c and...
Save Contacts to SIM blind. Nokia Broken Screen
Press Up once - Contact Menu
Press Up once - Copy Contacts Menu
Press Central Nav Button - From phone to SIM card
Press Central Nav Button - Confirm copy
Leave for a few minutes depending on how many contacts you have to copy
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
I accidently turned off my "wireless enabled" button my my acer netbook. I can't figure out how to turn it back on. what do i do?
Hi henrico,
Look on the front panel, below the lip of the keyboard. There's a slider that normally sits in a central position and can be pushed against a spring both left and right. It toggles the wireless ON/OFF. Slide it over (left or right) until the light above it (with the antenna logo) goes ON, indicating wireless is enabled, and slide it again to turn it OFF.
If this information was helpful, please rate it.
Thank you for using fixya,
Arun Zac
Dec 05, 2010 | Acer Aspire One Netbook 8.9" Notebook
Do you have the Nintendo Tetris game watch instructions?
Right red button toggles between game and watch. In game press right blue button to begin game with sound, left to begin game without sound. Use blue buttons for left, right, rotate(up) and drop(down). Clear twenty rows to go to next level. High score is recorded. In time mode press and hold left red button to set, Use left to set hours and right blue to set minutes. Press left red to set.
Oct 06, 2010 | Watches
I have a nokia 6021 and my screen is broken how do i transfare my numbers from phone to sim
This also maybe useful
Press left once
Press left once
http://www.fixya.com/uploads/images/eb5cca9.jpg
May 21, 2010 | Cell Phones
I bought a Sims 2 pet CD for PS2 and I need a manual to play.
The Sims 2: Pets
GAMEPLAY CONTROLS
Directional Buttons Up = Motives. Down = Wants and Aspirations. Left = Quick Text. Wants of Nearest Pet. Right = Relationships.
X Button Select. Action.
Triangle Button Cancel. Close Menu.
Square Button Pan Camera (Hold)
Circle Button Snap Camera to Sim
L2 Button Sim Switcher Menu (Hold)
L1 Button Freeze. Fast-Forward.
R2 Button Toggle Walls On/Off
R1 Button Freeze. Fast-Forward.
Start Button Pause
Select Button Toggle Control Mode
Left analog stick (L3 Button when pressed down) Move
Right analog stick (R3 Button when pressed down) Zoom. Rotate Camera.
PLACEMENT MODE/GRAB MODE CONTROLS
X Button Place or Grab Object
Triangle Button Cancel. Back.
Square Button Remove Object and Put In Inventory
Circle Button Toggle Blueprint Mode
L2 Button Clone
L1 Button Rotate
R2 Button Undo/Redo
R1 Button Rotate
BUILD/REMOVE MODE CONTROLS
X Button Place/Remove Wall, Wallpaper, or Floor
L2 Button Clone Wallpaper or Floor
R2 Button Undo/Redo
Combo #1 L1 Button or R1 Button + X = Build or Fill Room
Combo #2 L1 Button or R1 Button + X = Remove or Uncover Room (In Remove Mode)
acquired from (Gamefly.com)
Jul 06, 2009 | EA - Electronic Arts The Sims 2 Pets for...
How do i get rid of replace lamp message & reset lamp timer
If you are using the RM-PJ2 remote control, following these instructions. You will have 5 seconds to complete the key sequence.
1. Make sure the Projector is in "Standby" mode. There will be a red light instead of green
2. Press the Reset button
3. On the "joystick" type button, toggle the left directional arrow
4. On the "joystick" type button, toggle the right directional arrow
5. Press down on the "joystick" button to press Enter.
6. Your lamp hours should now be reset.
Recap: Reset, left arrow, right arrow, Enter, all within 5 seconds.
Mar 26, 2008 | Sony VPL-EX1 Multimedia Projector
Cant use speakerphone when sync is closed
I've found that the speakerphone only works closed when using the media player. Close your phone then hold down the right side key and navigate with the left side key, use the right side key to select an option. When in the media player the hold button is the right side key hold down to toggle on or off. If that is the answer your looking for.
Dec 06, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Sony Ericsson K750i Cellular Phone Logo
52 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
