Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
How does the red thing fit back into water tank
If that doesn't come up, type in bissell water tank into google & then select 'images' from the results. The large rectangular block of plastic is inside the tank between the clear plastic tabs. The long red plastic stick with the 2 tabs goes on top of the lid
Posted on Dec 24, 2009
I have the Bissell 9400 ProHeat 2X and it will not dispense cleaning fluid. Is there anything I can check?
YES! And it was amazingly simple. The soap dispenser has a red washer/gasket thing that fits over the nozzle. For clarity, it can be viewed here: http://www.vacpartswarehouse.com/Products-p/2036677.htm
The red part can come loose and remain inside the receiver where it fits snugly and looks like it belongs there. In this configuration, the tank cannot insert far enough into the receiver to open the spring valve and no detergent will flow. Simply remove the red piece from the receiver (I used small pliers), replace it on the tank nozzle, and the detergent will flow again!
Sep 07, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9200 ProHeat -the water tank won't fit on the base
sume time the rubber gromit comes of the base of the water tank and gets stuck in the base there the water tank fitts to the base if this is why take out of the and refit it to water tank and of you go
Jul 23, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
NO WATER OR SHAMPOO
They loose there prime on the pump when not in use. You can call custmer support on how to do it exactually right but here is how I do it. Take off front nose on the unit. Take off the water tank. Turn on and let it run for 1 minute. Turn off and put water tank (with liquid in it) on the front of the unit, under the nose that you removed. Perfect fit but looks odd. Turn on let it run for 30 seconds and test( push Spray button). When it starts working remove and put back tank and nose cover.It should work as the pump is now primed.
I had the same question 4 months ago and called Bissell.
Jun 23, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Not wanting to spray shampoo/water piece of ****!!!!!!!
Capt. Obvious fixes: Of course make sure there's clean water in the bladder of the water tank and soap in the soap tank, and make sure the dial is set to Floor Cleaning, not Tool Cleaning or somewhere in between.
Sometimes an air pocket inside the machine (even a new one) keeps water from flowing, until you reprime the Bissell's internal pumps. To prime the pumps the easy way, turn it on, then press, hold, and release the water-and-soap trigger a few times, waiting a few seconds each time.
Still nothing? Prime it the slightly harder way. Separate the two water tank pieces. Only have the base tank filled and mounted on the Bissell without the piece that sits atop the tank. Turn it on. Kneeling on the floor in front of the Bissell, reach up and press the soap and water trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel just a bit of suction. Lift your hand up and down a few times, a few seconds apart. Release the trigger and repeat a few times.
Still no liquids? If your Bissell has been used at least a few times, particularly if you didn't thoroughly clean the machine when finished, but after a year or so in a hard-water area like mine even if you are good about cleaning it, the water sprayers on your Bissell may have clogged with mineral deposits. This is a *fairly* easy thing to fix yourself, but please read all the way to the end and check out the GOTCHA before trying this.
Unplug the Bissell. Remove the water tank pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your roller brushes when you press the water-and-soap trigger at the top of the Bissell's handle, and tend to clog with mineral deposits.
Only work on one sprayer at a time so you can see how it goes back together.
As you squeeze the red plastic sides of one red water sprayer, push up on the underside of the sprayer from underneath the bottom unit of the Bissell to release the sprayer from its mount in the base. Clean any lint or debris out of the mount area. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove one water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip up the hose so it compresses the spring and is no longer on the red plastic water sprayer. (See GOTCHA about the spring, below.)
With the clip released, now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the end of the red water sprayer that was inside the hose in your mouth and seal your lips around it, and try blowing through it. If you can't blow air through it, it's clogged. Open up a paper clip and push it back-and-forth through the small hole in the hose end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Click the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
The GOTCHA: Once when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. It’s best to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, fix this by removing the six screws on top of the Bissell base (this is the surface the water tank mounts on top of), and pry it up. Pull out the hose, reattach the red water sprayers on the hose, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
You might want to prime the pumps again (instructions above). If the sprayers are clear, and the pumps are primed, but it still doesn't get the floor wet when it should, the problem may be more serious. You may need a pump or motor inside the unit replaced.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Thoroughly rinse out and empty both water tank pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and get all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and needs more pampering than a vacuum cleaner, doesn't it??
Jun 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Not wanting to spray water
Capt. Obvious fixes: Of course make sure there is clean water in the bladder of the water tank and soap in the soap tank. Also make sure the dial is set to Floor Cleaning, not Tool Cleaning or somewhere in between.
Jun 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet cleaner
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Jan 24, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
I cant get it to ****
This is from the owners manual that I have provided a link to, so that you can have a copy for your records. I hope this helps.
http://www.bissell.com/images/UserGuides/9500_908.pdf
Possible Causes Remedies 1. ReadyTools dial may be at wrong setting. 1. Set ReadyTools dial to either FLOOR CLEANING or TOOLS setting. 2. Tank may not be seated properly. 2. Pick up both the 2-in-1 water tank and formula tank and reseat them so they fit snugly on the unit. 3. Tank may not be assembled properly. 3. Check to make sure the "lip" of the nozzle is securely hooked into the groove on bottom of Tank (see page 9). 4. Solution or 2-in-1 water tank is empty. 4. Check fluid levels in heavy duty bladder and formula tank. 5. 2-in-1 water tank has picked up 5. Empty 2-in-1 water tank. Refill maximum dirty water and red float heavy duty bladder with clean door has closed. hot tap water and replace. 6. Red float "door" in the tank may have closed 6. Turn the machine OFF ( O ), as a result of bumping an object or moving allowing red float door to release into machine back and forth too quickly. the open position. Turn unit back ON ( I ) to continue cleaning. Be sure your forward and backward strokes are done at a slower pace.
Jan 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The water does not shoot out of my bissell proheat shampooer. The red spinner has stopped spinning.
I'm not sure I have the same kind of machine as you because I don't think I have a red spinner. However, I did have the problem of water not shooting out (although the solution was being used up, just not the water). The problem turned out to be the plug underneath the main tank. To find out if this is your problem, lift out the main tank and take it to the sink. Feel underneath for the plug. Push inside of it. Water should squirt out (assuming there is water in your tank). If it doesn't, turn the tank over, unscrew the plug, and push the thing inside until you get it to spring up and down. If it won't do that, you might need a new one. If it springs, screw it back and try your machine again. Mine worked good as new after I did this. Good luck!
Dec 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Pump prime lost
After further examination of the pump I re-installed it in the machine and removed the inlet hose from the mixer valve body and placed the end in a shallow pan of water. I turned the machine on and the pimp picked up the water from the pan and pumped without failure for several minutes as I had the pump output refilling the same pan.
If I take the end of the inlet hose out of the pan for only a couple of seconds, the pump loses prime and will not recover until I remove the vacuum hose from the pump. Upon replacing the vacuum hose the pump primes and begins working.
At that point I suspected an air leak at the base of the water tank or somewhere in the mixer valve assembly. I then took the hose off of the tank fitting in the base and placed the end of the hose in the pan of water. Again, the pump performed without any problem. Therefore, I assume I have an air leak at the base of the tank where the tank connects to the machine.
I will explore this further and provide you with additional info as I make progress
Jan 06, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
102 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
