Question about Cell Phones
How do i re introduce a remote unit to the base unit. a power outage resulted in a loss of contact to the base unit.
  • 3,230 Answers
Well first of all switch of both (remote and base unit) and just turn on them on the same time. hope it helps you to reconnect your remote unit to the base unit, post comments if further you have the same problem..... please let us know the model number to help you more....
Good Luck!!
Thanks
Posted on Dec 12, 2009
Power outage need to reset - blinks "CL"
remove the power adapter and remove the battery from the handset. Now replace the battery and power the base unit , place the handset on the base and select intercom or search remote.
The base unit must automatically set the frequency to mesh with the handset and handshake to connect.
Sep 19, 2011 | GE 25932 Cordless Phone
Our telephone and answering machine quit working after a power outage. Pushed reset button but nothing changed. The letter E is in the window of the base unit. When unplugged the power supply and...
it sounds like the unit has taken a surge, which is a common side effect of power outages. unplugging and replugging make fix the issue but since you have already tried this, i would reccomend contacting the manufacturer. See if a replacement can be given or if you have warranty on the unit.
The E is most likly a refrence to general error. the main board for teh unit was probably damaged by the power outage.
Mar 07, 2011 | Uniden EXAI 918 Cordless Phone
I have a ' Firenzi ' electric oven which has ceased to function after a recent power cut. The word ' STOP ' appears on the display. Can you help? Regards Norman Dayton
HI. This will occur when a surge has entered the unit, due to the power outage. Normally, there will be a power surge when the power is re-introduced to the home circuits after a brief outage. This will damage most unprotected electronics in this situation. The most vulnerable area in the unit will be the main control board. I would advise to try a hard rest. You can initiate this by simply shutting down the appropriate circuit breaker, or unplugging the unit for 5 minutes. Once the 5 minutes have passed, kindly re- introduce power to the unit, and try to run a baking cycle. If the word stop, or PF illuminates on the display, this will confirm that the surge has damaged the board. It must be replaced, in this case.
Nov 13, 2009 | Ovens
I have an HP c7180 all in one inkjet printer and recently we had a power outage. Ever since that time the colors are all mixed up. After the power outage, I was getting this error message: ""Ink System has...
If your product is in warranty then I recommend you to contact HP support to service or replace the unit. Otherwise perform the steps given below and verify the results.
  1. Turn on the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 7 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Oct 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
Power outage caused c8 / 76 error - No Hot Water
How old is your unit...if less than 5 years old tell Polam/Rheem customer support you are recieving a code 76 error - this is a loss of communication between the remote and the burner control assembly. Part will be covered under MF defect warranty. However, the part is covered....the labor to install is not.
If you are slightly technical you can install the part yourself...customer support will walk you through the process and they give you a step-by-step procedure to follow.
Sep 24, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Cant charge my Logitech 1000i
If you have compressed air, try to blow into the end of the power cable that plugs into the charging base as well as the the charging base port for the power cable. Make sure that you don't shake the can or moisture will result, otherwise give it a little bit and replace the power cable into the charging base. How long have you had the remote? Logitech is real good about warranty issues.
Thanks, 81
Jun 22, 2009 | Logitech Harmony 1000 LCD Touchscreen...
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
