Question about Ovens
Garland gas range
I have a garland range that I bought from a client. I do not know what model I have. Where can I find the model number. The oven does not light eventhough the iginition switch glows red. Can you help
  • 640 Answers
Look at the bottom panel below the doors.on the left and right side youll see screws--remove them.open the doors and you should see 2 more screws.pull the panel out towards you.youll see the serial/model number on it or the frame of the oven.if the glow coil is red try to manually light the burner witha paper towel.if the burner lights, the burner may be obstructed --if not the gas valve may not be opening.you will need a voltage meter to test the coil on the gas valve.if you get the correct voltage on the valve coil which is 24 volts ac and no gas the valve is bad.if you dont have 24 volts the ignition board is bad.let me know.
Posted on Jan 21, 2008
I NEED A PARTS MANUAL FOR A GARLAND CONVECTION OVEN MOD#ECO-G-10-E I HOPE YOU CAN HELP ME. E-MAIL ncf4031@tampabay.rr.com thank...
Seems to me that the easiest and quickest way would be to email or call Garland, or go online and get a toll free number. . .
Jan 18, 2018 | Garland Ovens
Oven cooks too fast and burns the food
My electric oven, Garland master 200 only reach a maximum of 250* and I only saw 1 of 3 elements turn red
Dec 14, 2012 | Garland Convection Oven - MCO-NAT Gas
Griddle top replacement
well this is different, but sounds like fun. I would just Repair the gas griddle you have. from the sound of it you need to replace the 3 or 4 tstats that control the griddle. If you are in a Metro area you can find a dealer for Robert Shaw and get the parts you need. but you may also start at http://www.garland-group.com/. everything there will be newer but you will be able ask about where the data plate is and then get parts lists. call a small comercial kitchen repair company and ask for help there too.
Jan 29, 2012 | Garland Ovens
Model TE2B garland does the fan run to move
The fan runs to circulate the heat inside the oven for more even and faster cooking...That is how a convection oven works :)
Jan 14, 2010 | Garland Convection Oven - MCO-NAT Gas
Garland oven MOD# MST43RE White flames and a lot of black.....
I adjusted the air mix, main burner was full of black stuff inside so took the air compresor and cleaned it good. Now i have nice blue flame!
Gasman77
Mar 25, 2009 | Garland M-2 Oven
When Oven turns off so does oven pilot
Hi there, it is possible of the pilot being too close, but usually does not have that effect, unless the pilot is too small. But if you replaced the pilot, it should be clean, so next I would look at the gas pressure, if this is too low, the flame won't have proper burning speed, and strength, and could get drawn out. The control valve may be of the type that has a regulator built in, you may need someone skilled at gas pressure measuring, to do this, your gas supplier, appliance professional, plumber, should be able to do this.
Let us know, and thank you.
Jan 29, 2009 | Garland GPD-60-2 Gas Double Oven
My garland air deck will not heat up
I own a large repair company we charge these fees for our tech. ability I often give you people free advise but when you insult our techs try to figure it out yourself then you will know why we chargey the way I would not give you free advise you would not say thank you
Dec 31, 2008 | Garland M-1 GL Gas Single Oven
GARLAND CONVEC. OVEN - CONVEC. NOT RUNNING
it sounds to me like the door switch is not making. if you take off the bottom panel the switch is to your rightat the bottom. make sure that you kil power first brfore you remove the panet.
Dec 22, 2008 | Garland Convection Oven - MCO-NAT Gas
Garland deck oven
your gas valve may be freeflowing you must have this checked right away
Sep 29, 2008 | Garland M-1 GL Gas Single Oven
Ovens Logo
303 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
