Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Phillips projection tv 55pw9363 has sound but no picture whats up
One person said capacitors or trippler whatever that is. is tv worth bothering with its 6 yrs old
  • Philips Master
  • 3,866 Answers
To answer you question about if its worth it?
This all depends on what is wrong with it, Keep in mind here Tech's here cannot L@@K T@uch and feel your TV, They cannot smell if there is something burnt. We are relying on you to use your eye,s ears nose and fingers to communicate your issues for a possible repair.
Get estimates from local repair guys Ultimately that is where this repair will end up. fixya only works if you have general "working" knowledge of TV repair or electronics. Can we fix it for $12.00 the answer is NO, We are not fixing nothing its actually you doing all the work while we guide you.
We give you information for a possible fix. We only can diagnose what you say and what you say is subjective and may not be the cause.
Capacitors play a huge role on how you tv reacts trust me if a capacitor gave out your tv will be acting funny or not powering on and the laundry list of issues will be taking place.
We at fixya meaning me and my fellow experts do this more or less as a public service the payment is so shortcoming for each of our answers to you. So think about the time and information we give when you do click the accept button. Try the methods others have given you.
IS it worth it? Well think about this your getting Educated, a possible fix and some experience for the price of the service so in my humble opinion it is worth every penny! Try our problem solving skills what if it was a $2 capacitor? What if it was a $12 dollar Thermal fuse wow you save $200-$600 on repair bills. Now as yourself this was it worth it?
If you like my portable e-book I written for you here please show support
for your expert and click the accept button- Thanks and have a happy holiday.
Posted on Dec 12, 2009
I have a phillips 55pw9363 my picture is hazy. It does not change when I adjust the brightness.
Tv pictures and screen brightness are dulls and have a halo glow to it wright?Yes.The tv CRTS TUBES guns have a chemical call CRTS TUBES coolants are contaminated require changing.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a chemical coolant kit to replace it.Kit also came with a tutoring DVD disc showing u how to replace the CRTS TUBES guns coolant chemical.
Apr 03, 2011 | Philips 55PW9363 55" Rear Projection...
Our Phillips HD projection tv has lost a picture. It started by blacking out once in a while but now the picture is constantly rolling. The screen is distorted and it's impossible to even recognize what is...
Cloudy,distorted pictures.The tv have R,B,G CRT tubes gun coolant probblem.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced.
Sep 11, 2010 | Philips 55PW9363 55" Rear Projection...
My Phillips 55PW9363 tv has a double image problem, how can i fix it?
Ur convergence is dead.Know to solders? Require changing 2 convergence ICS,and all the resistors.Tries Website Tv repair World.com,Tvrepairkits.com.for the convergence kit.Shop will cost U $300 for parts,and labors.
Jan 25, 2010 | Philips 55PW9363 55" Rear Projection...
I have static in the picture. Looks like a swarm of bugs moving around the screen. It is a phillips rear projection
sounds like poor tuner singnal solution mak sure u have gooddddddd connection with ant or cable make sure ur tv is on right station exe 2 3 4 this should resolved yur problem if not if you have bacis electronis skills i instruct u on repair
Jul 25, 2009 | Philips 55PW9363 55" Rear Projection...
My 55" Phillips Rear Projection tv has perfect sound but no picture at all.
Hello sdbeynon,
This usually denotes a problem in the high voltage section either trippler or the IHVT. Since this section of the Tv has hazardous voltages I would suggest that you get a TV repair technician to give you an estimate on the cost of repair.
Judging by what you described it sounds like the trippler may have a problem. Have the technician check that first, or if you have a high voltage probe here is the procedure:
1) Remove the rear of the Tv set
2) clip the ground lead of the HV probe to ground.
3) using the tip of the probe touch the input of the trippler block you should have a voltage of 20Kv - 30Kv
4) touch the individual outputs of the trippler block they should each read 20Kv to 30Kv.
If the input is not present the IHVT or the trippler is bad, however if the 20Kv to 30Kv is present on the input but not the output the trippler itself is the problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 18, 2009 | Philips 9P6031C 60" Rear Projection...
No picture or sound
Contact us at www.TvRepairKits.com. We are working on solving this problem as we speak.
Nov 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Phillips 55PW9363
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 24, 2008 | Philips 55PW9363 55" Rear Projection...
No picture
voltage tripler...and deflection bd........
Jan 13, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
