Question about Motorola Mobility W375 Cellular Phone
Motorola phone charger, port broke 1 prong can i replace or fix it
My phone does not turn on
Battery no good? Has your phone been holding a charge very long prior to this happening? Has your phone been exposed to any liquids??? A lot of phones have plug in chargers that are very delicate...look at the tip of your charger and make sure there is no damage, most importantly check your phone where the charger plugs into. some phones just have 1 simple round tip that plugs into the phone, others have these little flat plugs that have tiny metal prongs that if Not careful can bend or break taking in and out improperly. If everything looks in its place( metal prongs all there and line up with the connecting ones in the phones charger port, Always make sure your charger didnt go bad...Alot of chargers are cheaply made and will just Quit working, causing your battery to completely die and thus your phone will not turn on...You can go to almost any place that sells phones and have them plug in a NEW charger to see if it will turn on...Hope this helps...
Jul 08, 2012 | Motorola Mobility Triumph
My phone wont charge
The phone is not charging because:
1. The charger of the phone maybe bad. Test the phone with another charger or test the charger with another phone to confirm if the charger is defective or not.
2. The charging port of the phone maybe defective. In this case, the charging port needs to be replaced.
Good luck.
Jan 10, 2012 | Motorola Mobility Droid (2 GB) Cell Phone
One of my prongs in my charger port broke off in my phone. i do not have insurance on my phone and would really like to get it fixed. is it possible to fix it..
It is possible to fix if you can get the right prong and getting it soldiered on. You can try giving wireless image a call 303.482.1288 they do all types of repair. They are located in denver co
Oct 28, 2010 | LG Dare VX9700 Cell Phone
Charging no respance
Hi, problem can be solved. When charging a phone and it does not respond,it means that either the charger or the charging port where you fix your charger in is faulty.
First you can try and use another charger to check if phone will charge. If it charges, that means the charger needs to be replaced,but if not charging,charging port will need to be replaced .
Take care.
Jun 09, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Motorola L9 no cherging
I suggest you try to use another charger to use another charger to charge your phone, if it does not charge, it means the charging port is bad and will need to be replaced.
You can also use your charger to charge a similar phone to see if your charger is not the problem, if your charger charges the similar phone, it means the charging port of your phone is bad and will need to be replaced.
Replace the charging port and your phone will charge.
Take care.
Apr 23, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Won't Charge! :-(
Hi. these situations are mostly caused by a bent or broken copper prong that is located within the input charger port that is inside the phone housing.
When you insert the charge cord into the input port, there are copper prongs that will have to connect to each other and , this contact point will transfer the necessary current to the cell for a proper charge.
If the prongs are damage in any way due to broken copper or, bent copper prongs, this will prevent the necessary current from flowing to the cell.
Most remedies are crude like using a tooth pick or paper clip to straighten out the prongs inside the port. these methods do more harm than good and i recommend sending this phone in for a input port transplant. the manufacture or local repair depot is the best repair solution for this situation.
There is one thing that i would do before sending it to the repair depot. try using a completely different battery cell. if you purchase a new battery and the charger continues to not charge, this will confirm the input port failure.
Please rate and god bless:)
Apr 22, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Charger jack came out of the phone while connecting charger cable. This is the same port used to connect the phone to the computer for backups. It just gave way....and fell out of the phone.
Need to call your phone company and have your phone replaced. They will do it for free most likely. There is no way to personally fix the charger jack. Best of luck hope i helped! I used to own the same phone.
Mar 19, 2009 | Motorola Mobility Q9h Smartphone
Razr will not charge with wall charger
Your charger is faulty. If your phone is able to charge off of other sources (computer, car charger, another wall charger) Then, the charger needs to be replaced. Some mobile companies have a 90 warranty on accessories like the charger and battery. Then the mobile manufacture (Motorola) has a 1 year warranty on the charge and battery. I would check on that, and get those replaced.
Feb 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Will no longer charge the batteryh
You have a charging port problem. the part is here http://www.sourcingmap.com/mini-usb-charging-port-charger-connector-for-motorola-razr-p-24817.html ig you need a diagram ill see if i have time to load 1 up. or take it to 1 of these phone guys on craigslist. they wull fix while you wait got like $20.00 if not ill fix it. Merry Xmas
Oct 08, 2008 | Motorola Mobility RAZR V3
Motorola Mobility W375 Cellular Phone Logo
106 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
