Question about Mr. Coffee TFTX85 Coffee Maker
Model ftx26-1 stopped half way through brew cycle. Now clock doesnt appear to work. I thought perhaps I put in half enough water, so I added some-nothing. The clock shows no hour, minute or second hands. I pressed hour and minute buttons to set time-nothing. I unplugged the coffee maker and plugged back in-nothing.
  • 2 more comments
  • oasla2 Dec 13, 2009
    the clock stays lit with the green light as always. but am unable to set time on clock. There is no hours, minutes or seconds displayed, and I am unable to set the correct time, and also am unable to set the time I want the coffee to begin to perk.
    normally I add coffee and water, then press the brew now button. then the brew now light and the regular brew strength light comes on, and it begins to perk.
    now I added coffee and water, then press the brew now button . The brew now light and the regular brew strength lights both came on, but does not perk.
    power is fine. the clock lights up when power is applied, and the brew now light
    and the regular brew brew strength lights come on, but it will not perk.
    I found a fresh brew display button, which I had never pressed before. I pressed it. Now the clock displays fine. But the coffee maker does not perk, and the element under the coffee pot does not heat.
    I took the coffee maker apart and the heating element is open. do you sell them? it is 900watt,
    how much including shipping and handling?
    the fuse is fine. the heating element is open. where is the best place to get one?
    It is 900watt
  • 2,841 Answers
Sounds like there is no power to the unit. Are you 100% sure the receptacle it is plugged into is working? If it is in a kitchen it may very well be plugged into a receptacle that is protected by a GFIC. Look and make sure one has not tripped. If you find out that the receptacle is good and power is reaching the unit, then it may have an internal fuse. It is highly unlikely the heating element and clock went bad at the same time.
Posted on Dec 12, 2009
Testimonial: "he hit is on the head. I took the coffee maker apart and the heating element is open. I will replace it or buy a new coffee maker "
  • NOT ME Dec 13, 2009
    The coffee maker will have to be dissembled to check the heating coil to see if it is broken which I suspect is the problem. Unless you can do this yourself, it would not be cost effective to pay someone to repair it. It would cost more to repair than it is worth. You would be much better off buying a new coffee maker.
  • NOT ME Dec 14, 2009
    I too cannot find a replacement heating element and I looked long and hard. May I recommend a Bunn coffee maker. Very high quality, and will make a pot of coffee in 3 minutes. This model is excellent.
    http://www.walmart.com/catalog/product.d...
    I have had the one I have now for 15 years.
    Have a great Christmas.
  • 576 Answers
The brewing on coffee makers is caused by heating the water in a tube that runs under the hotplate. It rises up and falls through the grounds. In all likelihood, the hotplate stopped heating. In coffeemakers, this is often due to a blown thermal fuse. That would also explain the loss of power to the clock. Unplug it and take it apart (if you are so inclined) and find the thermal fuse. It should look like a small cylinder (usually ceramic) inline in one of the power wires coming in. Test it with an ohmmeter or continuity tester for continuity. If it is open, replace it. You should be able to find one online. Let me know if you need more help.
Posted on Dec 13, 2009
  • Charles Reifinger
    Charles Reifinger Dec 14, 2009
    I just searched the internet and I can't find anywhere to buy a new element. It seems Mr Coffee wants us to use their "authorized service centers" It is probably not likely that one of these centers would sell parts to someone wishing to repair a machine themselves.
Bunn CW Coffee Brewer not brewing enough coffee - amount is half
Have you cleaned lately, put in an empty filter and fill with cold water with a tablespoon of white/clear vinegar. Run the brew cycle, empty pot and while still worm fill with cold water again with out vinegar. Than check filter to see how much hard water chunks are in the filter. Repeat with and without vinegar tell filter is clean. One question though is there a lot of steam coming out of the top during the brewing cycle if so inside there is a tube that may be cracked, broken or came loose, have to look inside. requires opening or disassembling unit to check. REMEMBER when taking apart UNPLUG unit first.
Nov 17, 2015 | Bunn CW Aps Single Airpot Coffee Brewer,...
Need cleaning info
Manual version: Prepare a cup of white vinegar and 4 cups of water. Pour into reservoir and initiate "clean" cycle. Boiler was warm up, shut off and repeat over the period of about a half hour, and then finally cough up all the stuff and end the cycle. Then, fill with cold water and run a full brew cycle to rinse.
My version: Dump about a quarter cup of CLR into the reservoir, let stand for a half hour. Then, add 4 cups of water and run the "clean" cycle. After finishing, unplug and turn unit over over the sink to completely drain, use tap water to clean and flush the reservoir thoroughly, dry thoroughly and then plug in, reset the clock and brew time, and run a full load of drinking water/distilled water through to final rinse. It will last forever with my method.
Feb 19, 2013 | Mr. Coffee 12-Cup Programmable Coffeemaker
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
Water doesn't come down when brewing
I had the same problem, and it turned out it was the top needle that was clogged. I used a safety pin to clean out the needle and it worked again . . . I descaled immediately, just in case it needed that too. I am back to coffee goodness!
Jul 07, 2010 | Keurig B60 Coffee Maker
I PUT SWITCH ON FULL BREW AND IT STOPS WITHIN 30 SECONDS. WHEN I PUT IT ON HALF BREW IT DOESN'T STOP RUNNING
It sounds to me like the Timer board is damaged, to test it set the small lock lever on the board to on (hopefully you have the electronic timer board in there) then select the cycle half or full then hold down the brew button until you hear 3 clicks then release. After about 1min or if using a measuring pitcher stop the brewer a 2ltrs, by turning the on/off switch off. Wait until flow stops then check water level and note. Turn brewer back on and press and release brew button and this time if it stops and gives you the same amount as you just got when programming then the timer is fine, just recalibrate it for full brew using the method above.
May 18, 2009 | Bunn U3 / SS 20500-0000 Coffee Maker
Mr. Coffee won't brew - Mod. #ECX30118
IF YOUR HAVING ISSUES WITH THE ACTUAL BREW OR CLEANING CYCLE AND IT WILL NOT WORK, THERE IS NO TROUBLE SHOOTING THAT CAN BE DONE. MR COFFEE CARRIES A YEAR WARRANTY SO YOU SHOULD CALL THEM TO HAVE THEM REPLACE THE UNIT.
Jan 14, 2009 | Mr. Coffee FTX24 12-Cup Coffee Maker
This bunn coffee maker only brews half a pot what do u think is the problem. it is a 2 warmer on top and burnner on bottom. think model # is f15 of f20
be sure there is no water in it. put two pots of water in it. It should fill up the pot then. next time just ad one pot of water. and it should work right.It keeps some reserve water in the heated part.
Dec 06, 2008 | Heating & Cooling
Brewing stops mid cycle
Sounds like dosage is too high and grind is too fine.
Rule of thumb with any saeco unit.
Do not grind any finer then 2 or your looking for trouble.
Open grinder, clean it out with a vac. Slapped it back on.
The reason it stops is grind is too fine, and the machine doesn't have enough pressure to pass threw the grinds, creates back pressure in the machine and the unit failsafes after a certain amount of time with and pressure.
Back pressure is what blew your boiler.
May 16, 2008 | Saeco Magic De Luxe Espresso Machine
Won't brew
bring white vinegar to a boil and pour it into the perforated top, the water reservoir and the link between the water reservoir and the brew basket. let sit a few minutes, pour it out and do it again.
put the water reservoir back in, put water and vinegar solution ( half and half) in. Try to start it again. Mine did this last year and this fixed it right away. Try to clean the coffee maker using the vinegar solution once a month to avoid this problem.
Sep 13, 2007 | DeLonghi DCM485 Coffee Maker
Mr. Coffee TFTX85 Coffee Maker Logo
408 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
jmt
Level 1 Expert
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
