Question about Frigidaire Gallery Series GLRT83TEK 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Full-Width Glass Sh...
The gas burner is not lighting
I recently purchased a new Gallery series oven and some of the gas burners are either taking a long time to light or not lighting at all. You can see the igniter has flame when it's clicking along and you can smell gas, but it's not igniting. Hope you can help, AnnMarie
    Scholar:
  • 66 Answers
You may have an issue with not getting enough gas. Also it could be that the igniters are bad. Have a local repairman check it out, you dont want to mess around with a gas system without knowing what your doing just for safety sake.
Posted on Dec 12, 2009
Gallery series convection oven delivered new yesterday.First burner that was turned on(front,right side) doesn't work. The rest do.
Hello Karen, thank you for your post!
Since you just received your unit recently, let's try resetting the range. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the range on. If resetting the power does not correct the issue, your appliance could possibly have a faulty burner or a potential wiring failure to the burner. At this point, I would highly recommend contacting or visiting the manufacturer website to find a service provide near you and to verify warranty information. If there is anything else that I can help you with, please feel free to reconnect!
Best of luck!
Sep 19, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Burners slow to ignite
you may have your gass set to low or you need a new regulator valve
Apr 05, 2012 | Hotpoint Kitchen Ranges
Oven won't get hot
If your oven still uses a pilot light, it also probably has a thermocouple positioned in the pilot's flame path to detect whether if is safe to turn on the main burner. When the thermocouple fails, the oven thinks the pilot light is not lit and will not let gas flow to the primary burners. The part isn't costly (should be <$20 US) but replacing it may require some expensive labor.
Feb 11, 2010 | Frigidaire 30 in. Electric Gallery Series...
The lower burner in the oven of my Frigidaire Gallery Gas Range will not come on. The upper burner works fine.
The ignitor often goes bad and causes them to fail to light. The igniotr is easy to replace and will fix your problem.
This tip will help you understand this more.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | Frigidaire Gallery 30" Self-Cleaning...
OVEN WON'T STAY LITE MOST OF TIME & DOESN'T HEAT WELL:
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
Spark no gas
first off use a BBQ match and try to light one burner manually with the match. if it lights then the next thing to do is physically move the ignighter closer to the burner plate. if not then you should check the gas line as far into the stove as possible. and if you still dont have a flame then its either time (for the tool savey) to tear into it checking all gas lines and valves to see if they are open or you should call the repair man. sorry i couldnt be of more help
good luck
Jan 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
I just cleaned by hand by magic chef wall oven and now I can't
Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
Jan 02, 2009 | Magic Chef 9122 Gas Single Oven
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Gallery Series GLRT83TEK 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Full-Width Glass Sh... Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
