Question about Kenmore 62602 Electric Dryer
Need picture for route belt on kenmore dryer 80 series
  • 744 Answers
See the picture - yours should be similar:
Posted on Dec 13, 2009
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: can't find kenmore 80 series dryer drum belt
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Also for a manual I will include this website:
http://www.applianceaid.com/
Good luck,
I hope this helps
Posted on Nov 16, 2009
Testimonial: "many thanks... sounds like a lot of work unlike my old dryer"
Opened my kenmore 80 series to replace belt and found an arm with wheel laying at bottom.Trying to figure where it belongs
Hi and welcome to FixYa. I am Kelly. Use this link and look at figure 11 for proper routing.
http://repair2000.com/wpoolbelt.htm
If this is NOT fitting to your model of dryer please provide the model number and I will provide you with the routing diagram.
Thanks for choosing FixYa,
Kelly
Aug 16, 2010 | Dryers
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Belt tension part. it fell off and i need to know where it goes on the dryer. Kenmore 80 series gas dryer.
The bracket goes into holes on the floor beneath the motor pulley and looks like the picture of whirlpool in the link below when properly mounted:
http://www.applianceaid.com/images/belt-config.JPG
Oct 29, 2009 | Kenmore 62602 Electric Dryer
I have my kenmore 80 series dryer apart, and i am replacing the belt. having trouble configuring the belt around the pulley and motor, since the belt cannot actually go into the pulley, its sealed. help.
Kenmore dryers are configured in several different ways as far as the location and routing of the dryer belt. For drawings of how the belt is configured on your dryer, go to Repairclinic.com and click on the "Repair Help" link. On the following page locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to the Kenmore section and refer to diagrams H, B, or K. If you are not certain, please post back with your complete model number (located on a nameplate around the door opening) and I can determine for you. I hope this helps you.
Oct 23, 2009 | Kenmore 62622 Electric Dryer
I have a Kenmore 80 series dryer(118.72812101).
You may have something inside the workings of the dryer which has shorted out the heater coil. this could be the source of the noise as well. you need to remove the cabinet to access this, yet be careful as the drum will fall out on you in process. You can get a new coil from an appliance part store in your area. Take the dryer apart before buying this tho, so you don't waste your money on the off chance that this isn't the trouble. you will need make model and serial number from unit so they can match up the proper coil for you. Make note of how the belt is placed and routed for proper replacement when reassembling. Also make note of 'drum rollers' condition, as this could be some of the noise also.
Best to you, hope it works out
Joe
Aug 26, 2009 | Kenmore Dryers
Kenmore Series 80
You can find an exploded view at Sears Parts Direct, as well as get P/N's for the parts needed. I suspect the roller assembly came apart which caused the belt to fail.
You will need your Model number to locate the exploded view. If you can not figure out the routing from that, then order the service manual from Sears. It will show the routing and describe how to assemble and test most all aspects of the appliance.
Jan 15, 2009 | Dryers
Broken Kenmore dryer 80 series
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Oct 18, 2007 | Dryers
Kenmore 62602 Electric Dryer Logo
144 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
