Question about GE Spectra JBP78 Electric Kitchen Range
How do I remove the oven door from my GE Spectra Model J BP78W stove?
  • 1 more comment
  • jmattison Dec 13, 2009
    Got the door off and handles on, but the pictures and description don't match the hinges on this model. How do we get the door back on. The hinges have big springs on the top (in between the doors) and small
    __
    How do I get the oven door back on?
    The description and pictures don't match the hinges on this model. The hinges stay with the door (in between) and small pieces stick out from the door with knobs on the end that somehow latch in the oven wall. I have tried the broiler position but can't get the door to catch.
    Thanks
    Got everything out, handles on and door back on. The comments were helpful, but the honges/model were different so not the same.
    Thanks
  • 11,896 Answers
Oven door and door hinge help: There are There are way too many different types of hinges to talk about them all, but I have chosen a few of the common ones that I see. One common question is how do I get the oven door off or back on. Most hinges can be put into two different categories, ones that stay on the range and ones that come off with the door.
Some range doors can be opened to the broil position and then lift up on the door to remove the door from the hinges. Many gas ranges are like this and a lot of the electric ones have gone this route as well. One of the most common hinge in the one that comes off with the door.
One of the most common hinge is this one.....To remove the door, open the door to the broil position. Don't use the handle to remove the door, grab hold of the door itself. Lift slightly and with your hands pull out on the door...the lifting gets the hinges out of the keepers and pulling out will dislodge the door hinges from there holders. This picture should help you out. Manual clean doors are easier to remove than self clean doors because sometimes a metal clip is added to the hold the hinge in place on the self clean doors. The screw and bracket have to be removed to remove the door and hinges. The metal clip bracket has to be reinstalled once the door is put back on. To reinstall the common hinge, just do the opposite, start the hinge blade in the receiver, lift slightly on the door and with your knees push the door and hinges back into place.
At our shop, I get at least one phone call a week on these hinges. GE and Frigidaire are two major manufactures that use these hinges. Some of the newer GE oven doors can be lifted off and the hinges will stay on the range and most of the Frigidaire oven door hinges come off with the door. One thing most people forget about these hinges is that there is a clip that must be moved to hold the upper (A) and lower (B) parts of the hinge together. Once the door is put back on, the clip must be put back in the rest position. To reinstall the door, put the door at a 80degree angle to the range front, push in the larger upper hinge parts first and then lower in the smaller hinge parts, push the clips forward into the rest position and close the door.
On this style of hinge, one common problem is the hinge will sometimes "pop" forward against the range instead of staying still while you reinstall the door onto the hinges. If this happens, use a screw driver at the marked spot to help hold the hinge open so you can start the door onto the hinge, them remove the screwdriver to finish installing the door.
Appliance Repair Aid sections Appliance & Household tips Appliance Fun Stuff Applianc
Posted on Dec 12, 2009
WHERE CAN i FIND MODEL NO ON A GE SPECTRA GAS STOVE
The model number is most commonly located on a nameplate along the oven door opening, or the bottom drawer opening. Some model ranges may have the model number on the back of the operator console. If you need further assistance, please let me know. I hope this helps you.
Oct 05, 2010 | GE Spectra JGBP35 Gas Kitchen Range
GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Dec 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Glass top on range is broken.
pull bottom panel out look on stove middle just below oven door
thumbs up
Aug 17, 2009 | GE Spectra JBP78 Electric Kitchen Range
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Trying to remove oven door
ge spectra elec., how to remove the oven door
Jan 30, 2009 | GE Spectra JBP78 Electric Kitchen Range
I don't remember how to use the self cleaning feature
Remove everything from the inside of the oven, lock the door if your model has a latch handle that you move from left to right to lock the door, then set the oven selector switch to clean.
Dec 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
GE Spectra JBP78 Electric Kitchen Range Logo
132 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
