Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Kitchenaid dishwasher dishwasher is 5 yrs old. Recently the dishes don;t look dry and sometimes aren't clean even when you use the scrub feature. Hot water works at sink but we don't see steam coming out of dishwasher and the door doesn't feel hot to touch as it used to. Help please.
  • Anonymous Mar 26, 2014
    Pro scrub and heat dry lights work normal when selected
    Sergeant:
  • 351 Answers
May have a heating problem.need to check for power to element,if no could be board fault,broken wire in door,if power is getting to element the the element could be faulty.hope this helps.
Posted on Mar 20, 2008
Cleaning Light flashes 7 times then repeats 7 flashes again. Cant find model #.... About 6 years old.. Thank you
342f192.jpg techbuster
  • Rank: Guru dishwashers_small.png
  • Rating: 92%, 2877 Votes
  1. Crack open door
  2. Within 3 seconds push Hi-Temp Scrub, Heat Dry, Hi-Temp Scrub, Heat Dry
  3. Close and latch door
  4. Press Cance
Try the above steps and also check the video in link given below to know detailed explantion on what the light means
http://www.youtube.com/watch?v=Hv7xOaucH7I
Jan 19, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Our ten year old kitchenaid dishwasher doesn't get the dishes clean. there is food particles left on dishes if we don't completely rinse our dishes. is there a cleanout filter that needs to be emptied?
Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
Aug 29, 2010 | KitchenAid Dishwashers
Not washing well
Hi
First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 30, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Bad smell on dried dishes after being washed.Stale water smell.
correct, no filters to clean, but what you are smelling is soap residues that have built up on the heating element and when it goes thru the heat dry cycle, it burns the soap causing the odors.
trying the cleaners you have may help but the cause is the residues. you need to use a d/w cleaner like d/w magic or citric acid. if you just run the unit with the waterheat option and vinegar in a bowl right side up in the top rack, it should rinse out the residues then dont use to omuch soap and only use dry powder soap. no tablets or liquids.
run hot water at the faucet first and then be sure to use the heat option. it may take a few cycles to get rid of the odor but it will go away as you get the unit cleaned out.
Jan 06, 2009 | Dishwashers
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Buzzing noise and won't clean
An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.or may be its due to
Heater fanIf the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Jul 16, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
227 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
