Question about Maytag Ovens
I have a Maytag electric built in oven, Model cwe9000bcb. F-1 code was displaying on clock. I had a repairman out and he replaced the sensor in the back of the oven. He told me that the circut board needed to be replaced. The part # is 7601P214-60 and is no longer being manufactured. I had the part re-manufactured by CG Industries and put it back in and the code came back, I brought it back they re-repaired and I re-installed and the F-1 code is still coming on. Is it possible the problem is something other than the cicuit board?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The other issue might be with the supervisory relay enable which is shorted or sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. If still the issue persists, then check the touch pad or clock assembly (ERC). Replace whichever has gone bad. However the touch pad is a more common problem. Please follow these steps to test to determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective---
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 12, 2009
My oven display has "sABBATH" written on the
May I get the make and model # to help you more. On some ovens if you hold the clock button for secondes it should turn off. I need the make and model # to be-sure.
Apr 24, 2011 | Maytag 24" Built-In Single Electric Wall...
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
Model CRE9600CCM Serial 24625851SK. When we turned on the oven, we got an error message "F-5". What does this mean? What do we need to do?
Here is a list of codes for Maytag-- Does this help:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Let us know if we canhelp further,
Mack B
Jan 23, 2011 | Maytag Ovens
What does F- mean on my jenn air expressions electric wall oven? If it means what I think, then this is the 4th failure in 10 years. This just can't be right!
Common fault codes:
Oven Fault Codes
May 22, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
We have a gas maytag gas wall oven that is getting f3 and f5 error codes
F3
Shorted or open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
F5
Watchdog and hardware conflict
Replace clock (ERC).
Jul 17, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
What does an F1 fault indicate
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC) * Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
Jun 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F2,F5,F7 message
MAYTAG
Code
Feb 07, 2009 | Maytag MEW5527B Electric Single Oven
Maytag oven calibration
Maytag single built in oven model cwe9000bcb beeps intermittenly. Reset stops for about 1 minute. Two control panel boards replaced since 2002 with same problem. Can it be fixed?
Dec 18, 2007 | Maytag CWE4800A Electric Single Oven
Ovens Logo
41 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
