Question about Motorola Mobility i850 Cellular Phone
How do I load contacts from outlook to i856 - Motorola Mobility i850 Cellular Phone
What's the sim unlock code for the Motorola I856
You can get the unlock code for Motorola I856 from any trusted online vendor. For example you can get it from www.Wickedunlock.com This site provides accurate unlock code for affordable cost. You can get a best solution for your mobile too. Unlocking process is very simple here. You will get complete guidance on unlocking process.
Apr 15, 2012 | Motorola Cell Phones
I want to unlock my motorola i856, what is the procedure
You can Unlock it simply using the Unlock code,You can get the Unlock code from the site
www.mobile-unlocker.com
and Follow the instructions and unlock it step by step.
Motorola I856 Select your current network to see a list of available unlocking services noimage.gif Network Provider Select your Current Service Provider
Motorola I856 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Motorola I856 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola I856 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola I856 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola I856 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola I856 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Oct 22, 2011 | Cell Phones
Special code for motorola i856
You can get the special unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
May 31, 2011 | Motorola Mobility i856 Debut
Need a special code to unlock a Motorola i856
unfortunately these are not compatible. nextel is an iden carrier, while att is a gsm carrier. it's like apples and oranges. If you need to transfer contacts then you can get that done at any best buy. they will usually do it for free or for a minimal cost.. good luck
May 04, 2010 | Motorola Cell Phones
UNLOCK I856 TO T-MOBILE
The i856 is an iDEN phone.  iDen runson BOOST Mobile/Nextel ONLY.  It cannot run on t-mobile, which is a GSM system.  It is not possible, even if you unlock the phone, they are completely different radios and networks.
Mar 10, 2010 | Cell Phones
My screen went blank or white, on my brand new motorola i856 .. i recived a text ... hit reply .. and bam ,,, blank white screen ... 4 days old ... what do i do ???
This reply is somewhat late, but, the WSOD on the i856 is thought to be caused by the ribbon cable breaking or tearing in the slide.  If it is under warranty, contact motorola.  But do it quickly, the phone only has a 90 day warranty.
Dec 02, 2009 | Cell Phones
How do i load music into my new i856 by boost
according to motorola, this phone has bluetooth and micro SD card slot.
if you have computer with bluetooth, then you can pair the computer and phone and simply send music files wirelessly via bluetooth.
if you dont have bluetooth, then you can buy a cheap usb bluetooth adapter from ebay and have a bluetooth enabled computer, then follow above step.
if you have SD card slot on your computer then you can get a SD card to micro SD card slot adapter from ebay or elsewhere, where you can simply put music on then card from pc and then transfer the card to the phone.
here is the phone manual.for safety read the whole manual.
p.55 for music and p.79 for bluetooth instructions.
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i856/US-EN/_Documents/Static_Files/i856_UG__%20Boost_NNTN7815A_.pdf
Nov 06, 2009 | Motorola Mobility i850 Cellular Phone
How to transfer Contacts in iPhone to Outlook
Once your iPhone is connected to your PC and iTunes is loaded you can right click on your iPhone and select exactly what you want to have sync'd.
1. Under the Info tab you will find Contacts. 2. Tick the "Sync contacts with :" and select Outlook from the list. 3. Click "All contacts"
If you wish to put all of your iPhone created contacts into a different group in Outlook you can select the group there also and tick the relevant box.
iTunes always displays a warning about over writing data but that is not relevant to Contacts. Data is always merged.
I hope this solves your problem.
Chris
Apr 08, 2009 | Apple iPhone Smartphone
Linking contacts to emails in Outlook 2007
I down loaded the ms office 2007 professional on 6th April 2008. Now it is not active. What shall I do to get it activate again.I try to down load again but I couldn't down load the ms office 2007 professional trial version
Apr 06, 2008 | Microsoft Office Professional 2007 Full...
Moving contacts from outlook to a mobile phone
1. Go to Outlook and save your 957 contacts in an outlook file. 2. Delete the 507 contacts you don't want to synchronize to your phone and save your outlook under a different file name (e.g. Addr450). 3. Connect the phone to the PC. 4. Open Nokia PC Sync. 5. In the Nokia PC Sync dialog, click Synchronise Now. The Create Settings wizard opens. 6. On the first page of the wizard, select the PIM application you want to synchronise the phone with from the drop-down list. You can choose Outlook Express, Outlook 2000, outlook 2002 or Outlook 2003 as your PIM. Follow the instructions on screen to finish the wizard process. HTH.
Apr 24, 2007 | Nokia 7610
Motorola Mobility i850 Cellular Phone Logo
153 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
