Question about Bosch Dryers
Bosch wte84102 classixx condense tumble dryer at first it kept stopping drying now it's not doing anything
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
  • 3 Answers
SOURCE: bosch classixx condenser drier
The problem is with the lower water tank float switch, it is stuck. Take off the right hand side panel (as you are facing the machine) at the bottom you will see a spring mechanism for the belt tension. Beside this there are 2 electrical connectors. Take them off and spray with wd40 or similar. Whilst off give the plastic box they fit 2 a light tap with a hammer to free the float switch. Reconnect and try. If this fails you can over-ride by leaving the left hand of the two plugs off. This will get your machine working but you will not have an indication as to when the water container needs emptying so you will need to remember.
Posted on Feb 14, 2009
  • 57 Answers
SOURCE: Bosch Classixx tumble dryer just stopped heating -
its the heater bosch are known for this fault
Posted on Jun 23, 2009
SOURCE: Bosch Condenser Dryer Classixx
I found this on justanswer.com, I am going to try it this weekend and I will post an update.
"Ok if you remove the left hand side panel then located at the back is the drain pump
remove the hose on it which goes up to the bottle and blow up it to make sure its clear.
If thats fine then remove the pump and clear any fluff thats in there and make sure the impeller is ok and turning fine.
Then refit and try again hopefully this should sort it out.
let me know if you need anymore info."
Posted on Jan 02, 2010
SOURCE: Bosch classixx tumble dryer container full light
This is happening me too. Have you had any suggestions how to solve this problem???
Posted on Oct 11, 2010
Bosch WTE84122BY Condenser Tumble Dryer dosen't starts
Did you check the res to see if it was full? Might be clothes inside the door and it aint shut all the way? never even seen a condenser dryer.
I have the model service manual though HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 11, 2013 | Bosch Axxis WTA4400 Dryers
How do you change the drive belt on a Bosch Classixx tumble dryer WTA3003GB/17?
Its a fairly simple process depending on your machine. Most Bosch machine belts are simple to replace. Here is a good resource: http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
Dec 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Our Bosch Classixx Condenser Tumble Dryer works but there is no heat. I have cleaned the Condenser Unit and the filter and emptied the water, but still no heat. Please advise. Thanks Craig
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
Feb 26, 2010 | Bosch Axxis WTA4400 Dryers
Bosch classixx condenser dryer won't turn on
try replacing the thermistate fuse link
Dec 04, 2009 | Bosch Axxis WTA4400 Dryers
Bosch classixx tumble dryer container full light keeps coming on which is stopping the cycle but container is empty
Nov 16, 2009 | Bosch Dryers
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Leak during tumble cycle
more than likely that the seal for your condensing chamber has become faulty easy fix undo any screws that hold the condesing chamber on get some bath/shower sealant that is waterproof put this around the chamber and put it back on you will have to leave it for a couple of hours but this should fix the leaking problem its not totaly common but this does happen m8
Dec 27, 2006 | Bosch Classixx WVF 2402 Front Load...
Dryers Logo
174 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
