Question about GE JE2160 Microwave Oven
Microwave Blowing Fuse. Fixed. After Day, Fuse Blows Again.
I have a GE JE2160 Microwave and it went dead. I replaced the fuse and it worked for about a day before it went dead again (likely the fuse). What should I replace with the fuse? Is it something I can do?
  • GE Master
  • 3,051 Answers
Hello there:
If you have all ready changed out the fuse and it has happned again i would first check to see that the fuse is the right one for the machine (i am sure that you did this but please recheck ) next i would look at the controle board as the next culprit it maay be failing expecially if there were any pops ar sparks that was noticed before the initial failure.
Also check to see if all of the wires by the board a re not loose or looked burned ar if there is any grease or anything like this around the area
And finally check to see if the plate is turning ok and not sticking cause this would cause the microwave to overload and it wil make every fuse you put in there fail after just a couple of uses ok
SO please try all of these things that i have explained to you
I hope this is very helpful for you.
Best regards Michael
Posted on Dec 12, 2009
  • Michael Thomas
    Michael Thomas Dec 12, 2009
    Somthing that you may want to have checked out is the door switch when they start to fail they will cause the same thing to happen ok
    regards mike
  • Michael Thomas
    The PC Board, the cavity thermostat, the low voltage transformer, or the magnetron thermostat could cause the same symptom.
  • 11,896 Answers
If the fuse keeps blowing, then you have another faulty component. Something is either shorting out or is wearing out and cannot handle the power being sent to it. It could be a capacitor, a relay, the fan, power supply ect. Testing with a volt & ohmmeter will be needed to find the faulty component.
After about two days fuse blows.
replace the shorts switch and the proper amperage fuse
Dec 06, 2013 | GE JE2160 Microwave Oven
GE spacemaker XL microwave oven blowing fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the house fuse or breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Here's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 26, 2012 | GE Profile Spacemaker XL 1800 36 in....
Trying to change a fuse in ge microwave oven je2160. however, we can't determine how to find the old fuse and remove the cover
THE FUSE IS ON THE RIGHT HAND SIDE OF THE MICOWAVE AS YOU LOOK AT IT JUST AT THE TOP BEHIND THE CLOCK
Dec 25, 2010 | GE JE2160 Microwave Oven
GE JES1855 1100 Watts Microwave Oven not working. Display lights do not come on. Checked wall plug and it is ok.
Sounds like internal fault protection fuse blew. can be fixed by qualified technicians. their is very high voltage coils and capacitors within this unit and can cause harm or death instantly if not discharged properly.
Aug 12, 2010 | GE JES1855 Microwave Oven
Yesterday, my sharp carousel r-1460 went dead. I took apart the front keypad and replaced the 20amp fuse behind it. the microwave light and fan work.But, when I start microwave to cook something, pop! fuse...
If the 20A fuse is blowing, it is often the high voltage transformer or magnetron. If this is the case, and the microwave is not under warranty, replace it. Residential microwaves are generally considered disposable. Parts and labor are just too expensive. A magntron or transformer can cost more that half the cost of a new microwave.
Feb 24, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
GE SpacemakerXL Microwave blowing fuse
If its blowing fuses more than likely there is a short somewhere. Make sure you are putting the required size fuse in. Also never put in a higher than recommended amp fuse you could catch the house on fire.Unhook the fan motor and see if the microwave will run. Anything can be fixed but the cost of doing so may be more trying to fix, but really it could be cheaper to buy a new one instead of trying to fix that one. IMO
Aug 24, 2009 | Microwave Ovens
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Oven JE2160
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 22, 2008 | GE JE2160 Microwave Oven
GE JE2160 Microwave Oven Logo
603 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
