Question about Kirby G6 Bagged Upright Vacuum
My vac doesnt have a neutral lever. are they easy to install
  • Kirby Expert
  • 324 Answers
See the instructions how to replace N/D pedal:
http://www.goodvac.com/kb_results.asp?ID=16
If you need any parts or supplies you can find them on our site
Good Luck,
Rocky
Posted on Dec 15, 2009
  • 85 Answers
No they are pressed on the tranny has to come out
Wiring the switch on my l250 shop vac idk which color wires go where
doesnt really matter. however to be safe, I would wire Blue as the hot switch lead and brown to the neutral side.
Oct 16, 2016 | Shop Vac Vacuums
My G7D kirby vac was accidently dropped and the D & N lever came out of the machine. When I put the lever back in the hole it belongs in it is very loose and it doesn't switch from D or N.
The drive/ neutral pedal assembly must be replaced. This part is pressed together and cannot be repaired. A new assembly is about $17-$20. The power drive unit must be removed from the machine.
Jan 23, 2011 | Kirby Ultimate G Bagged Upright Vacuum
The auto drive doesnt work. The lever even fell off the back.
Its not a simple fix, it will involve some disassembly of the motor unit, especially if the mechanism would not change from neutral to drive. One of the vac experts at vacuumland.org, a collector and enthusiast website, may be able to provide detailed instructions with pictures.
Sep 30, 2017 | Kirby Ultimate G Bagged Upright Vacuum
My button for the neutral and drive won't work. a metal piece broke off and no i can't switch the transmission
Find an authorized Kirby Dealer in your area and have the part professionally installed. Very complex. Many parts and screws. If no Kirby store, find a Vac store you trust. Or go here http://reviews.ebay.com/REPLACING-OR-REPAIRING-KIRBY-VACUUM-NEUTRAL-DRIVE-PEDAL_W0QQugidZ10000000011180003
Oct 03, 2009 | Kirby Generation 3 Bagged Upright Vacuum
No Power to Windsor Sensor XP12
The Windsor Sensor vacs all have a removable handle.
The handle is inserted into a "socket" which has contacts to complete the electrical circuit.
The handle is held in place by a gray plastic lever.
If the lever is not pressed down completely, the handle is able to slide within the socket during regular use.
If the handle slides out far enough, the electrical connection within will be disconnected and the vac will have no power.
Simply lift the lever, pull up to remove the handle, and re-insert the handle fully, then press down firmly on the lever to lock the handle securely in place.
This is the first step to solve your problem and hopefully this is all that need to be done.
If this does not work, please repost here and I will help you all I can.
Note: I am a big fan of the Windsor Sensor vacs and find them to be easy to work on and a great vac all around!
Aug 12, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Hoover Self Propelled wind tunnel vacuum U6433-900
please go to thehooverstore on the web. they'll have an exploded diagram of how your machine goes together. I'm sure you'll find your solution there.
Sep 02, 2007 | Hoover Ultra U6430-900 WindTunnel Bagged...
Emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Aug 02, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Kirby G5 Transmisson
I know the lever you're describing, but it's very hard to tell someone how to put it back on. There's nothing wrong with your transmission, by the way, this is a part that's meant to be moveable, and it just happened to slip off in your case. You may call us at 1-866-509-1952, and we can do our best to help you.
Jul 01, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
60 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
