I cant get the modem & router to communicate
When I type the ip address in the browser nothing happens when I click stay offline so I can not get to the wizzard
  • 591 Answers
What IP address are you typing in to your browser, and what do you expect to happen when you do this?
It SHOULD get you to the router management program. You MUST be online when you are doing this, it can not be done offline. Router IP is either http://192.168.1.1 or http://192.168.0.1 depending on manufacturer. Connection should be via CAT-5 cable router to computer. Trying to do initial setup wirelessly can be VERY frustrating, as wireless access is not yet established.
Posted on Dec 13, 2009
I cant get my NAT open for my Xbox360 because I cant figure out how to get to the area where im able to open the NAT for said system
Hooking up an Xbox with Linksys routers:
Open an Internet Explorer browser page.In the address bar type - 192.168.1.1
Leave username blank & in password use admin in lower case...
Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" subtab...
1) On the first line in Application box type in ABC, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
2) On the second line in Application box type in PQR, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
3) On the third line in Application box type in XYZ, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...
3) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...
4) Click on set-up and change the MTU Size to 1452 and click Save Settings...
5) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your Xbox
IP Address :- 192.168.1.20, Subnet Mask :- 255.255.255.0, Default Gateway :- 192.168.1.1...
6) Also assign the DNS Addresses on the Xbox
Primary dns :- 4.2.2.2...Secondary dns :- 192.168.1.1
7) Turn off your modem, router, and Xbox...Wait for a minute...
8) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect...
here is a website to help you setup the Xbox Live:
http://support.xbox.com/support/en/us/xbox360/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 28, 2011 | Linksys by Cisco Cisco Valet Plus Wireless...
Constant flashing light on WGA54G wireless gaming adapter. Won't connect to router. won't communicate with xbox or computer
Thanks, Joe
Feb 01, 2011 | Linksys LKS-WGA54G Wireless-G Game Adapter...
Help configuring my router
Hi Friend,
Please follow the steps in order to resolve the issue:
Make sure you have connected each and every wire/cables to their respective ports/places.
1. Open web browser and type the IP address of the TW100-S4W1CA in the address bar. The default IP address is 192.168.1.1. At the LOGIN, click LOGIN and click on Advanced Setup.
2.Click on WAN and then click Dynamic IP on the left hand side, then select Dynamic IP (Cable Modem) and click on Apply.
3.If your ISP has registered the MAC Address of your computer that you are managing the router from click on Clone MAC Address. This will copy your computers MAC Address to the Router. If you are not managing the computer from the computer with the registered MAC Address make sure you enter the registered MAC Address manually.
4.Click on Apply.
After saving the settings you have to power cycle the modem and router(Turn off the modem and router for 15-30 seconds).
* Reconnect the modem first and wait for it to boot up.
* After the modem has booted up reconnect the Router. Open the web browser and type the IP address of the TW100-S4W1CA in the address bar. The default IP address is 192.168.1.1. At the LOGIN, click LOGIN, then click on Advanced Setup.
* Go to System then Status on the left hand side of the screen
* If there is no WAN IP listed in the WAN section on the right hand side of the screen, click Renew and wait for it to come back with an IP address
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 07, 2010 | Trendware TRENDnet TW100 S4W1CA...
How do i setup the 3g wireless internet on the dir 412?
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password (blank by default), and then click Ok or Log In .
Also:
Step 1 Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing).
Note: The address 192.168.0.1 is NOT on the Internet. The web-based configuration is built-in to the router.
Step 2 Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes.
Step 3 Power cycle the cable modem and router:
  • Turn the cable modem off (first)
  • Turn the router off
  • Leave them off for 2 minutes**
  • Turn the cable modem on (first)
  • Wait until you get a solid cable light on the cable modem
  • Turn the router on
  • Wait 30 seconds
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 30, 2010 | D-Link DIR-412 Mobile Broadband Wireless...
My google chrome is not loading the web page
well there are several things why your google chrome does not work. here are some tips:
check if you have another browser other than google such as internet explorer, netscape, firefox , determine if you have internet access
If it has, then uninstall/ reinstall your google chrome..
If it does not then check your physical connections on your pc
check the lights on the modem / router if it is all lit, if it doesnot , contact your modem/router provider. If it works, then proceed to next step:
Then type the "ipconfig" command on the command prompt by clicking start > all programs > accessories > then click command prompt
if the IP address starts with 0.0.0.0 or 169.xx.xx.xx consult your Internet service provider, if it is 192.xx.xx.xx then proceed to next step:
Type the ip address 192.xx.xx.xx on the internet browser, if it replied , then configure your router settings to make sure that the other ip addresses would work on the internet browser. Then type www.google.com or www.yahoo.com if it work. If symptom persist, consult your internet service provider.
Hope this help....
May 08, 2010 | Google Chrome
1720dn Laser Printer: printer offline. unable to set online....
I Open my browser....I signed in to my router as administrator ....
Mine is 192.168.1.1 ....
I went to status in my router ....
Then to local network ....
Then to DHCP Clients Table ....
This is how I found what printer address the was.... Then I typed the printer ip address into my browser
Mine happened to be 192.168.1.105 ....
Yours will probably be different....That got me to the 1720dn printer menu ....I clicked on Configuration ....
I clicked on Print Server Settings
I clicked on TCP/IP
I clicked on Set static IP address.
I changed IP address from 192.168.1.105 To 192.168.1.125
and Submit....Now you can get to the printer menu at 192.168.1.125
Go to run....
Printers & Faxes
Right click on Dell laser printer 1720dn
Properties. Ports ....
Add port ....
Double click on Dell Enhanced TCP/IP ....
I named the port My dell laser 1720 dn....Where it said enter a single IP address or host name I entered the new address 192.168.1.125
the clicked OK ....
Properties....Ports
Choose your new port ....
May 06, 2010 | Dell 1720dn Laser Printer
Hello, i type in the modems address, 192.168.0.1 but it wont let me access the setting page to try to configure wireless settings, i'm running win 7 64 bit, and cant even find a dos command to ping with
To get to the DOS prompt , Go to start and type " cmd" enter. Then you can use the ping utility. I had a problem on a new dsl modem and after many hours trying to fix it, It was a bad modem. It worked for a week then nothing. They finally replaced it and it worked. Some time being new doesn't mean its not broken. I learned it the hard way.fd93cca.png
Dec 18, 2009 | NetGear DG834G Router
Will not connect to internet completed all connection but cannot connect to internet
Router's have their usual way for them to work with your preferred Cable / DSL Internet Service Provider.
Cable Internet usually requires a MAC clone and power cycle to work properly while DSL Internet often required a username and password that came with your DSL povider.
If you want to configure your D-Link router then try accessing it Web Interface;
This instruction is for Cable modem installation however if you're using DSL modem then just change the WAN connection type to PPPoE and type your user name and password.
  • Wait 30 seconds
Step 4 Follow step 1 and log back into the web configuration. Click the Status tab and click the Device Info button. If you do not have a public IP address under the WAN heading, click on DHCP Renew and then click Continue. It may take a few minutes to obtain an IP address.
Hope this helps!
Oct 15, 2009 | D-Link Computers & Internet
Router as cable modem
This answer is for a Dynamic and Static Cable connection (I.E. ATnT-BI, Cox, Adelphia, Rogers, Roadrunner, Charter, and Comcast). Note: Please configure the router with the computer that was last connected directly to the cable modem. Step 1: Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2: Click on the Basic Setup tab. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Save and Restart. Step 3: Click on the Device Status tab and verify that you have a solid link between the router and the modem. If you do not have a solid link between the modem and the router follow the steps below: # Turn the cable modem off (first) # Turn the router off # Leave them off for 2 minutes** # Turn the cable modem on (first) # Wait until you get a solid cable light on the cable modem # Turn the router on # Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes. Step 4: Follow Step 1 again and log back into the web configuration. Click the Device Status tab . If you do not already have a public IP address under the WAN Ethernet heading, click on the DHCP Release and Renew buttons. Setup Static Cable Connection Step 1: Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2: Click the Basic Setup tab. Select the Static IP Address radio button and enter in your static settings obtained from the ISP in the fields provided. Note: If you do not know your settings, you must contact your ISP. Step 3: Click on Save and Restart. Step 4: Click on the Device Status tab and verify that you have a solid link between the router and the modem. If you do not have a solid link between the modem and the router follow the steps below: # Power cycle the cable modem and router. # Turn the cable modem off (first) # Turn the router off # Leave them off for 2 minutes** # Turn the cable modem on (first) # Wait until you get a solid cable light on the cable modem # Turn the router on # Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
Cable modem connection
Step 1 Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Note: The address 192.168.0.1 is NOT on the Internet. The web-based configuration is built-in to the router. Step 2 Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes. Step 3 Power cycle the cable modem and router: Turn the cable modem off (first) Turn the router off Leave them off for 2 minutes** Turn the cable modem on (first) Wait until you get a solid cable light on the cable modem Turn the router on Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes. Step 4 Follow step 1 and log back into the web configuration. Click the Status tab and click the Device Info button. If you do not have a public IP address under the WAN heading, click on DHCP Renew and then click Continue. It may take a few minutes to obtain an IP address. Static Cable Connection The instructions below are for users who were given a static IP address from their ISP (Cox Business, TDS DSL, PacBell Business, Interbaun, InReach, Inficad, FlashCom, DCAnet, and Cavalier). Step 1 Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2 Click the Home tab and click the WAN button. Select the Static IP Address radio button and enter in your static settings obtained from the ISP in the fields provided. If you do not know your settings, you must contact your ISP. Step 3 Click on Apply and then click Continue to save the changes. Step 4 Click the Status tab and click the Device Info button. Your IP Address information will be displayed under the WAN heading.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
David Payne
David Payne
